Old 03-25-2011, 06:15 AM   #271
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
no
Old 03-25-2011, 07:10 AM   #272
Trader Rating: 55 (100%+)
what is the difference in the sport and regular models? I am in the market for a WGT
Jamison R is offline   Reply With Quote
Old 03-25-2011, 07:18 AM   #273
theisgroup's Avatar
sport runs the old school front end (asc block)
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-25-2011, 08:04 AM   #274
avs
avs's Avatar
curious about the formula front end. it looks like you adjust ride height by shimming the whole front end as a unit.
does this mean that a ride height adjustment means you must loosen and retighten fasteners that are threaded into GR/EP lower plate?
how does those threads hold up for some of us less delicate pit mechanics?
Tony Shimko
avs is offline   Reply With Quote
Old 03-25-2011, 08:16 AM   #275
theisgroup's Avatar
yes you loosen 6 8-32 screws and insert shims and then re-tighten. bruce make the shim so that you do not have to completely remove the screws. mine last about 1 year of racing before they start to get loose. but since, I have been helicoiling some of the parts so that I don't have to worry about it anymore. i helicoil the front end, body posts, and antenna mounts right of the bat.
yang lai
Old 03-27-2011, 05:32 AM   #276
hanulec's Avatar
Trader Rating: 27 (100%+)
Looks like Donny Lia and Peter Robinson are doing very well at the 2011 ROAR Carpet Nationals by making a bunch of A-mains. Good luck today guys...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-02-2011, 09:46 AM   #277
303slowdown's Avatar
Trader Rating: 24 (100%+)
Do you guys widen the rear of the car to 172 or run it narrower. My car with jaco's is 167 so i thought id ask.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 05-02-2011, 11:24 AM   #278
hanulec's Avatar
On carpet.. widen it up as much as you can. The width can exceed 172 if rules, or lack there of allow so
Old 05-02-2011, 12:37 PM   #279
Thanks Mike i appreciate your help.
Ryan Borgheiinck
Old 06-14-2011, 08:20 PM   #280
hanulec's Avatar
Default 1/12th scale practice at Jackson RC
asphalt anyone?
+ YouTube Video
Old 06-15-2011, 01:26 AM   #281
Bring it FJ!
Old 06-20-2011, 09:10 AM   #282
Hay Guys I need some help . Recently at my local track the crc guys with the help of Max Kuenning have found a magical setup that has put them ahead by a few tenths a lap. If someone could give me a setup for 17.5 blinky that carries a ton of corner speed i would greatly appreciate it. I cant be having Mario Ficco Beating me on a regular basis lol.
Ryan
Ryan Borgheiinck
Old 06-20-2011, 09:29 AM   #283
hanulec's Avatar
Ryan
Do u know what tires they are running? Is it magenta f/pink r? If so they are running a super twitch/evil setup -- but that should cause ficco to blow out . Can u post your current setup?
Old 06-20-2011, 11:07 AM   #284
For tires they're running gray(f) and yellow (r) witch i have tried and have been running and dropped about a tenth in lap time.
Current setup is
same tires as stated above
.20 front springs
-1.5 camber
2deg. caster
4mm ride height
Red center spring
40 wt oil
red tube spooge
.20 side springs(3 turns down from top)
3.5mm ride height
.5mm pod sag
1mm pod droop
4mm rear ride height
Ryan Borgheiinck
Old 06-30-2011, 06:42 PM   #285
champebi's Avatar
Default 2011 IRCC International R/C CAR CHAMPIONSHIP
Speedmerchant REV.6
Kazuki Endo 2nd place
Naoki Watanabe 7th place
champebi is offline   Reply With Quote
SpeedMerchant Rev 5 flameoutgarrett Electric On-Road 619 04-30-2010 01:45 PM
Speedmerchant Rev.4 Yankey Electric On-Road 1413 02-22-2008 09:24 AM
FS/FT RC10L30 & SpeedMerchant Rev 3 primusblowsgoat R/C Items: For Sale/Trade 10 12-31-2007 12:20 PM
FS: Speedmerchant REV.3 W/Extras!!! boomer01 R/C Items: For Sale/Trade 7 09-03-2007 03:21 PM
