Old 04-20-2010, 01:34 PM   #1
Default MM Pro + Novak 8.5
I'm going to pair a 8.5 Ballistic motor to a MM Pro ESC tonight but needed help on the wiring. The wires coming from the Castle ESC are red/white/black and from the Novak it is red/yellow/blue. Do I pair them by blue to black, yellow to white, red to red?
Thanks for the help.
Casper06 is offline   Reply With Quote
Old 04-20-2010, 01:59 PM   #2
If it's a sensored system you need to wire up the phases correctly A to A...B to B...C to C.This should be marked on the motor and esc.If it runs backwards you need to reverse it via the esc programming
If it's a sensorless system you can wire them up in any manner and if it runs backwards switch any two wires
hope this helps
Steve
imgumbydammit is offline   Reply With Quote
Old 04-20-2010, 05:17 PM   #3
Goingfast's Avatar
Trader Rating: 29 (100%+)
hi
The red wire for A and white for B and black for C
Looking from the back of of the motor. from left to right is A,B,C
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 04-20-2010, 05:34 PM   #4
Thank you guys! I'm excited to get this running should be pretty sweet to have all that tune ability of Castle with a Ballistic motor.
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 11:51 AM
Castle Creations Mamba Max Pro Sensored ESC bkspeedo Electric On-Road 1512 12-24-2014 08:06 PM
Novak Havoc rccar306109 Radio and Electronics 218 11-17-2011 10:05 AM
My 5lb 1/8-buggy (DBX8e) JSR Electric Off-Road 42 01-28-2011 08:34 AM
