Old 04-23-2004, 01:10 PM   #16
fatdoggy's Avatar
R/C Tech Charter Subscriber
For the reedy quad mag, people at my local track run rollouts very close to stock. Very fast but I've seen a few get fried.
fatdoggy is offline   Reply With Quote
Old 04-23-2004, 02:14 PM   #17
Originally posted by berger
Under section 5 of the 2003 rules which can be found in pdf format on the brca website, not timing limitations are mentioned except for 27 turn turn motors which have to have a fixed 24 degrees of timing.
Berger, you need to read ALL the rules.......
"7.3 All rebuildable standard or stock motors must be of the bushing type with an end bell that locks the timing advance at 24 degrees. .............. "
....and before you say anything, this rule DOES apply to the 19 turn class motors as well. There is a subsequent rule allowing the use of ball raced bearings in these motors..
modeltech is offline   Reply With Quote
Old 04-23-2004, 02:32 PM   #18
raving-monkey's Avatar
Send a message via MSN to raving-monkey
toooold yaaaa
i thought the rule was that it had to be stuck at 24 degrees...and mr modeltech just prooved it.
thx
raving-monkey is offline   Reply With Quote
Old 04-23-2004, 04:00 PM   #19
berger's Avatar
My rule 7.3 covers formula one cars, as i said im not reading from the complete rules just the downloaded version so have your rolleyes back And your not going to run an illegal adjustable timing motor anyway are you.
berger is offline   Reply With Quote
Old 04-23-2004, 05:53 PM   #20
at our track everybody runs about 3 to 4 teeth larger on 19t over stock gearing. the C2 I still believe is the best 19t out there. my reedy quad mag is a dog no matter what brushes, springs, gearing I run on it.
Masterfaster is offline   Reply With Quote
Old 04-23-2004, 07:01 PM   #21
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
hi!!!!
has anybody ever tried MATRIX 19T motors (specially the team modified quadmag 19S)?????
anyaway, i would like to see some dyno numbers from 19t motors......thanks!!!!
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 04-23-2004, 07:58 PM   #22
stankulas's Avatar
if you want the most bang for the buck go whit the c2 its my favorite motor good balance bettween torque and rrrr"s and very forgiving if you over gear this is the only motor that has ever seen 3-4 comms in it. one of the wors't is the binary 19t extrmelly fast for the first 6 runs and then use it for a fishing line weight its that bad. reedy quad i have mixed fellings on it it is very torquey i cut the timming tab on it and ran it at 36deg and it was the fastest 19t i ever ran but turned the comm red
RC America
Xray
Hudy
stankulas is offline   Reply With Quote
Old 04-23-2004, 08:19 PM   #23
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
stan, part of the reason that the comm went poof is that the timing needs to be turned down to around 12 degrees. I actually was on pace with Mike once I went down to 12 degrees and I know the motor needs more work.
I got some word from Big Jim that anything basically above 15 degrees will seriously impact this motor and cause the magnets to go soft.
Stan, try and rezapp the magnets and put your timing at 12 degrees and give it a run this sunday.
Old 04-23-2004, 08:22 PM   #24
fatdoggy's Avatar
I cut the tab off one of my stockers a while back(mvp with stand-up brushes). When I hooked it up to a 4 cell and increased the timing slowly while it was running the rpm's slowly went down, when I went slowly back to 0 degrees timing the rpm's went slowly back up. WTF? any ideas?
Old 04-24-2004, 02:41 AM   #25
crazy.....i thought advanced timing gave more rpm and negative timing gave more torque.
i was also told my someone that if you wanted to increase/decrease the timing with laydown brushes, it wouldnt have no effect unless you cut have of the brush face off....you get what i mean...is this true?
Old 04-24-2004, 03:24 PM   #26
TheCoolCanFanMan's Avatar
many tanks for all that info. I am racing tomorrow in a national and will let you know how I got on with the tips
Thankx
TheCoolCanFanMan is offline   Reply With Quote
Old 04-24-2004, 04:52 PM   #27
right, i have a reedy quad mag, my dad also does.
can i ask why mine is a dyno version, but my dads isn't...i was told by the lhs guy that they came in the same delivery....are some dyno versions and some not...as they were the same price
Old 04-25-2004, 01:15 PM   #28
fatdoggy's Avatar
They dyno'd version may have 767's instead of 766 brushes. They probably have the same springs.
I tried advancing the timing again today and it did the exact opposite. At 36 degrees timing the motor sounds a touch slower then my monster rpm wise but it has boat load more torque. Other then having to up the trim to get rid of the drag brake effect of the timing, it should be good. Heats up like a mother though.
Old 04-25-2004, 01:28 PM   #29
ok, thanks for that.
i ran my dads motor in the final last night (he decided not to run, not sure why :S)
anyway, i couldnt feel any different in them, well obviously i could coz one had been used more than the other so the comm and brushes were worn more on one.
but other than that they feel identical
Old 04-27-2004, 05:07 PM   #30
Ok guy's here goes, I used the Ready Quad 514 which is the dyno version, wasnt sure what brushes came with it though (maybe I should have left them in?). I put some, dare I say Schumacer KRY brushes which gave me loads of tork out of the corners and plenty of staight line speed, changed them for 766 did not seem as good though. Put myself 10th in the C, final and came 6th in the first leg and 7th in the second leg, I could have come 5th but me and another guy came together and both spun on our lids, another car came round the corner and rolled me onto my boots again, but waited for the marshal to turn the other guy over as well, and both went on racing but came 7th
Regarding the Reedy Chrome, I did not get around to using it nor the Chameleon 2 as I loaned it to a much younger a better driver than my self. I have 3 more nationals to do and will use the other 2 motors then and possibly before
Regards T,T,
EA motors 27 turn, new or in vgc markny R/C Items: Wanted to Buy 0 07-03-2008 07:46 AM
19 Turn motors- lot of 4 rcguy1958 R/C Items: For Sale/Trade 1 02-21-2008 03:04 AM
Single turn and double turn motors Wreckless_Daz Electric On-Road 5 08-21-2007 02:35 PM
27 turn motors. noblesavage Australia For Sale/Trade 0 01-23-2007 08:28 PM
19 TURN MOTORS, STOCK MOTORS, 767 BRUSHES, F BRUSHES, 2 MOTOR CASES LOSIMANJRXS R/C Items: For Sale/Trade 47 10-21-2006 06:06 AM
