Which new electric car to buy?..help!
OK gang! I am looking for a new touring car to buy and I want your honest opinions. I have been looking into the Pro 4 and the Xray Evo 2. I am open minded and looking for opinions. What about Barracuda and Tc3 and others? Also what are your opinions on belt verses shaft drive. I currently drive a Pro 3. Any help and input will be appriciated.
RaveOn!
RaveOn!
Anything is a step up from the Pro 3
My qualms with the Xray and the Barracuda is that in my area, the parts support is minimal (less so for the Xray). They are all good cars which can be made to work by certain people. The Pro 4 has the same oneway drivetrain issues as the Tamiya Evo3 so if you get it, buy alot of oneway gears. I'd look at parts support in your area: you don't wanna have to order online every time you break something. As far as shaft v. belt, I haven't driven a shaft car in a while and they're supposed to be slower in acceleration. I have a Tamiya 414M but I haven't noticed any acceleration given up to the shaft cars. The few times I do get out accelerated by a shaft car for whatever reason, I'm usually past him down the straightaway.
The only car you listed with good parts support is the TC3. The pro 4 has poor support currently, the xrays have always had poor support IMO and the only support the cuda has is through speedtech (reliable support). I run a cuda and i just stock up on common breakable parts like ring gears, and maybe chubs but i run the aluminum and they just don't break.
Actually, speedtech is about the only place i've seen that consistently has the parts I need and in my area, the local shops only support the TC3 (which is a car i don't like) and i'm forced to use the internet for support. No big deal.
I don't buy the competition between shaft and belt drive trains but i prefer shaft as I don't have to replace the shaft nearly as often as a belt. Otherwise, if I were to go with another belt car it'd have to be the xray factory kit and i'm getting a cuda r3 soon.
Whatever you pick, just stick with it and learn how to set it up and it doesn't hurt to have a few parts lying around so you don't have to rely on the local shop.
Hmmm, me biased about a product, naaah!! I highly recommend the TC3. There is excellent product support, the tuning posibilities are endless, shaft drive is way better than belt and if you go Factory Team, all the hop ups are there. But this is my opinion based on owning one for three years.
I was in the same situation the past few weeks,
I wanted to upgrade from the TA04 and my choices were
HPI Pro 4
Xray T1 Factory
TRF 415
all three have dismal support here in Aust and needed to purchase everything online,
in the end I decided on the Xray Factory kit, just finished building it last night and I am very pleased with the result,
HPI Pro 4
Xray T1 Factory
TRF 415
Either the Tamiya Evo III, HPI Pro 4 or the Yokomo MR-4TC SD
I run a TC3 with a IRS conversion.....its a good car but there are better, more ballenced F/R shaft driven cars out there
Plus....You'll have a much easier setting the toe on a bellcrank car
Originally posted by Sushi Boy
Any of the sedans nowadays are awesome cars. You just have to spend time setting them up. Look at what your hobby shop or track stocks as far as parts, then look at what the locals are driving. Usually if there is a dominate car there is a reason for it.
-Sushi Boy
-Sushi Boy
Belt versus shaft? Shaft is mainly hype. My old trusty HPI Pro2 can easaly follow and most often beat, TC3's, Yoke SD's, Evo3's and more on the track. The main difference is still the driver
One thing I personally dont like about shaft cars, is the torque steer and bad balance. Thus it's common to use uneven setup from side to side, for example droop differ from side to side... In my opinion, that's making it harder to achieve a good setup.
Assuming part support is okay: The shaft car, which tempt me the most (but not enough to buy
My personal favorites are the Schumacher MI2 and the Xray Factory edition.
budget also matters
damn,it's very frustrating.
On the same note,the batteries are almost always going to be heavier than the motor+electronics.
I don't understand why there are still cars with batteries on 1 side and everything else on the other.
Originally posted by cHckbOY5
budget also matters
budget also matters
