Old 04-13-2010, 02:36 AM   #1
rs-racer's Avatar
Default HPI F10
I don't hear alot about the HPI F10? I got mine a few days ago, i'm going to build it today Does anyone else have one?
Traxxas Rustler VXL/H&M skater XL/MHZ micro ice berg/HPI micro RS4/TGR Sinister/TT FM-1e/HPI F10
rs-racer is offline   Reply With Quote
Old 04-13-2010, 09:52 AM   #2
Micro-E's Avatar
Yeah, I have one. I like it - it's different than the common Tamiya or F109, drives very smooth with no bad habits. I am a relatively new racer so the stability suits me.
I have added the ball diff (not really sure that was necessary), the aluminum shock, and the alum motor mount (this is CRITICAL for the car).
- Erik
Micro-E is offline   Reply With Quote
Old 04-13-2010, 09:53 AM   #3
Micro-E's Avatar
Oh yeah, forgot.... I never tried the kit tires due to all the negative comments. I went straight for the HPI 'S' tires.
- Erik
Old 04-14-2010, 08:29 PM   #4
Does anyone know if the HPI rims/tires are the same size as the F103 ones? They look pretty much identical in the pics.
Old 04-14-2010, 09:53 PM   #5
prhess's Avatar
For rubber tires its 12mm hex on all 4 corners...same as f201.
I am assuming that foam rears are 12mm as well, but I do not know if the fronts use the same size bearing as a f103 (F103 uses 5x8x2.5mm). Some of the kit bearings are not metric, so the front wheels may not be either??
prhess is offline   Reply With Quote
Old 04-14-2010, 10:02 PM   #6
Ah...I see they changed it from what they first showed at one of the early model shows...that one showed the ball diff as having the same style hubs as the F103 and the rims for foam looked identical. The front wouldn't be too difficult to fit to a F103 as you would only need the F103GT knuckles and axles...the rear I'm not so sure on.
Old 04-14-2010, 11:46 PM   #7
lightfoot's Avatar
does anyone know if the HPI F10 rubber wheel fits on the F104 ?
direct fit ? Modification required ?
I tried to put HPI rubber on a F104 wheel... the rears fit 90%... pretty tight fit... the fronts deform the tire so much it's unusable...
Love and Peace...
lightfoot is offline   Reply With Quote
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
hpi f10 $85.00 shipped flippz R/C Items: For Sale/Trade 13 01-06-2010 07:50 PM
