Old 04-11-2010, 07:31 PM   #1
TonyK's Avatar
Default Removing anodizing
I have a 12 L4 and want to remove the anodizing off the aluminum. Is this possible and what would I use?
A large part of their history is made up of blood and battle. This is not something to shrink away from as a fancier of the breed. Their history should be embraced, understood, and once we have a full understanding, we can control the future.
TonyK is offline   Reply With Quote
Old 04-11-2010, 07:43 PM   #2
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Easy off oven cleaner, if you let the parts sit in a bath of it, with slowly get anodizing off as a home remedy.
Of coarse, you can send the parts to us, we strip them and throw some black or clear anodizing on them for you.
-Mike
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 04-11-2010, 07:46 PM   #3
I removed the anodizing off my SV27 hardware by using oven cleaner. Spray it and let is sit for a while then scrub it with a scotchbrite pad. Some parts needed a few soakings before it was all removed. This will give it a dull look that you might not like so be sure to try a small part or small area before you go to far.
Make sure to buy the good stuff, not sure if the cheaper brands will work.
Hope this helps,
good luck
chummer is offline   Reply With Quote
Old 04-11-2010, 07:50 PM   #4
TonyK's Avatar
Hey Mike, Can you do more colors besides black? I have an idea and sent you a PM.
Chummer thanks for comment sounds like I might not like how its comes out.
-Mike
ALUMINUM ANODIZING mcf74 Electric On-Road 188 03-06-2006 04:55 AM
ALUMINUM ANODIZING mcf74 R/C Items: Wanted to Buy 30 12-11-2005 06:05 AM
Sand Blasting- removing anondising??? xray racer Electric On-Road 13 09-29-2005 06:24 AM
Removing anodization? edseb Electric On-Road 20 10-15-2004 11:33 PM
