Old 04-09-2010, 03:59 PM   #1
KWT-NITRO's Avatar
Default need help, Carpet Track Discs/dots !!!
hey guys,
we are in the process of building an indoor carpet track and am gathering all the info and material needed.
am trying to find those round discs/dots to use them as apexes in corners, i do have the Losi ones but they are a bit small for 1/10. i saw few tracks in europe and the US where they use bigger ones, where to buy them ???
also how do you fix them on the carpet?? do you use any type of glue or what??
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 04-09-2010, 06:33 PM   #2
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by KWT-NITRO View Post
hey guys,
cheers
Ali
I know some use tractor dots, but those are very big and heavy. If you find ones with a flat base you can use velcro on the bottom to affix them tot he carpet.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-09-2010, 08:17 PM   #3
Slotmachine's Avatar
Send a message via MSN to Slotmachine
hey guys,
cheers
Ali
What you seek is called a Plow Disc. It is used to plow up the earth on farms, towed behind a tractor.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-09-2010, 09:33 PM   #4
Trader Rating: 29 (100%+)
A company called Roadrails makes dots(road domes). You can attach them using velcro or tape. I think there around 150dollars for 25.
RSTECH is offline   Reply With Quote
Old 04-09-2010, 10:21 PM   #5
artwork's Avatar
Trader Rating: 62 (100%+)
http://www.muchmoreracing.com/store/...oducts_id=1875
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 04-09-2010, 11:56 PM   #6
timmig's Avatar
Trader Rating: 25 (100%+)
Default Corner markers
Go to the Calif racing threads---
Check out the last races at TQ Raceway in Chino California. If you watch the videos and check out some of his corner markers--on the sharp 180 degree corners--he use a curled loop of flat plastic sticking out in a horseshoe shape---it allowed the car to "brush" against it and keep on going with a tight corner line!! It didn't damage the cars---- Or hold them up unless they were WAY to tight. No corner dots---and the track worked really well. Check it out--you may decide you don't need the dots!!!
FWIW
Tim
timmig is offline   Reply With Quote
Old 04-10-2010, 04:46 PM   #7
KWT-NITRO's Avatar
Hey guys,
thanks for the answers
will these work??
http://cgi.ebay.com/Set-of-100-Disc-...item5884aacad5
cheers
Ali
Old 04-10-2010, 07:04 PM   #8
shesha's Avatar
Send a message via MSN to shesha
Bro...
I already have those with me so need to by them, those are plastic will do the job for now.
In an ideal word Stainless steel would be better.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 04-10-2010, 08:55 PM   #9
Jochim_18's Avatar
PLOW Disc is your best bet they are stable due to their weight. They come in different sizes starting from 5 inches but I suggest 10 or 12 inches PLOW disc. a lot of farmers gave away use plow disc you just have to ask.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 04-10-2010, 09:12 PM   #10
RaceAce701's Avatar
Trader Rating: 86 (99%+)
+1 they work great
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 06-14-2010, 01:05 AM   #11
KWT-NITRO's Avatar
haven't found anything yet
i would like something like this
http://www.youtube.com/watch?v=5K2JM...eature=related
any help
Cheers
Ali
Old 06-14-2010, 07:20 AM   #12
robk's Avatar
Trader Rating: 22 (100%+)
http://www.integy.com/st_prod.html?p...146&p_catid=16
Old 06-15-2010, 01:11 AM   #13
KWT-NITRO's Avatar
thanks a million man
i dont think they have them in stock though, it says early july
thanks again
Ali
