CEFX 2010 - A new Evolution. >
Old 12-19-2010, 11:25 PM
  #646
OVA
OVA's Avatar
Trader Rating: 83 (100%+)
Originally Posted by 29TC View Post
Anyone having stripped spur gear issues? I have killed 2 64p & a 48p spur gears. I have checked that all screws are tight.
I noticed that the chassis flex and might be the cause of the gear mesh to bind up occasionally.
Anyone have input on this problem?
Put on two TC Pulley Post Mount...it is the
spur gear holder..the will hold the spur from moving or flex....
OVA is offline
Old 12-20-2010, 05:43 AM
  #647
29TC's Avatar
Thanks. I'll order one and try.
29TC is offline
Old 12-20-2010, 05:50 AM
  #648
yokemad's Avatar
same thing happened to my car twice but as soon as I mesh Spur and pinion a bit tighter (closer) than my other Cars problem has been solved
single Post and no problem at all ...
yokemad is offline
Old 12-20-2010, 09:26 AM
  #649
OVA
OVA's Avatar
Don't forget ..you have to have the standard Photon center spur shaft with two 3mm screws....
OVA is offline
Old 12-20-2010, 02:16 PM
  #650
sprintcarracer's Avatar
Trader Rating: 26 (100%+)
Has anyone found a fix for the chassis bowing.
sprintcarracer is offline
Old 12-20-2010, 03:25 PM
  #651
Default CEFX VS PHOTON LIPO
Seeing as the photon LIPO chassis appears to be a 'rip off' the cefx, has anyone compared a Photon Lipo against a CEFX
if so what are your findings?
Lohan is offline
Old 12-20-2010, 09:08 PM
  #652
OVA
OVA's Avatar
Yes I have....I like the look and design of the cexf chassis..but the cefx chassis setup is very narrow window compare the PHOTON stiff lipo chassis...
OVA is offline
Old 12-21-2010, 10:39 PM
  #653
29TC's Avatar
Has anyone been able to communicate with CEFX? I tried email to order some parts for the evo and no reply.
29TC is offline
Old 12-22-2010, 06:08 AM
  #654
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 64 (100%+)
did you email here [email protected] ? Or shop here http://www.cefxspeedshop.net/page/1r71l/Shopping.html ?
Jamison R is offline
Old 12-22-2010, 06:24 AM
  #655
29TC's Avatar
The website said not to order online so i emailed them instead.
I emailed them at [email protected] and have not yet gotten a reply.
29TC is offline
Old 12-22-2010, 07:16 AM
  #656
Jamison R's Avatar
I have ordered online with no problems. I made an order last Monday. Got it Friday. I think the website needs updated as it says webstore says parts will say 0 availibilty. When I add to cart, it works fine.
I do agree that the CEFX customer service could be a little better. Without James Reilly I would have never seen a set up sheet for Evo.
Josh- Do you visit this thread anymore?
Old 12-22-2010, 07:17 AM
  #657
Jamison R's Avatar
Last Activity: 10-07-2010 01:10 PM
guess he may be really busy
Old 12-22-2010, 07:26 AM
  #658
I guess nobody has an answer for this!
Old 12-22-2010, 07:31 AM
  #659
29TC's Avatar
Did you order from the new site or old one?
I can't order or register on to the new site cause I am from overseas. The new site "cefxspeedshop.com" only allows US residence to register an account.
29TC is offline
Old 12-22-2010, 07:43 AM
  #660
JamesReilly's Avatar
Trader Rating: 59 (100%+)
Originally Posted by JamesReilly View Post
Haywood,
"I have found this as well, I only get it if I tap something pretty good.
Try turning the rear top deck mount the steel one 180deg and re-installing it.
With manufacturing tolerances it could be off. I would also try a new/different top deck if possible. Also make sure that the carbon spur gear support doesn't hang below the motor mount. We have also taken to simply putting the car over your knee and tweeking it back, with your knee roughly near the motor. ( I don't like this method, it has been successful ).
Best regards,
James"
We have four guys at the local track running the car and these things have taken care of 95% of the problem, hope that helps.
Mr. sprintcarracer
There is no one "fix" for this as no one has been able to determine the exact cause of it, however above are a few simple things that we do to keep everything flat. I hope that helps.
James
JamesReilly is offline
