CEFX 2010 - A new Evolution. >
Old 11-22-2010, 08:06 AM
  #601
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Well just a update that setup is no good for a track that has newer clean carpet and med to high traction . I chased a setup all-day yesterday with no success. But I'm sure its not to far ofwf. I ended up raising the role center and shooting the camber links,also flipped the front arms and used#2 holeThink if I was to go with a thicker oil it would been on point.
jlfx car audio is offline
Old 11-28-2010, 08:45 PM
  #602
hay has anyone notices that the evo chassis has a "belly" from front to rear startin fron the back of the top deck and is about 2mm out/down when measured at the rear of chassis?
i have loosened and re tightened the screws in the chassis and top/ rear decks time and time again and every time i pull the car off the track its back to the same way. it hasnt made the car drive any different unless chassis drags and remidy or experience of this issue love the car tho
Old 11-29-2010, 04:08 AM
  #603
Hi,
check once the motor plate. Release times only the screw from the motor plate and see if the chassis is still bent.
Torsten is offline
Old 11-29-2010, 11:07 PM
  #604
Havnt checkd them loose but i have loosened then and retightened them.
But after a run ity back to the same "belly"
Old 11-30-2010, 12:05 AM
  #605
JamesReilly's Avatar
Trader Rating: 59 (100%+)
I have found this as well, I only get it if I tap something pretty good.
Try turning the rear top deck mount the steel one 180deg and re-installing it.
With manufacturing tolerances it could be off. I would also try a new/different top deck if possible. Also make sure that the carbon spur gear support doesn't hang below the motor mount. We have also taken to simply putting the car over your knee and tweeking it back, with your knee roughly near the motor. ( I don't like this method, it has been successful ).
Best regards,
James
JamesReilly is offline
Old 11-30-2010, 05:22 AM
  #606
hana166's Avatar
Best regards,
James
Knee tweak works perfect haha !
hana166 is offline
Old 11-30-2010, 07:19 AM
  #607
yokemad's Avatar
my Chassis also always like a banana on a flat setupboard but ok on setup Blocks and Track no tweak issue !
yokemad is offline
Old 11-30-2010, 09:03 AM
  #608
Your absolutely correct the “bowing” front to rear doesn’t effect the tweek at all, it does effect is the belt tension and makes it easier for it to come off.
Also it can affect the droop and ride height settings giving an erratic handling car. Most of us ck the droop and camber fairly often so the wheels are off it easy to ck or
I just ck my belt tension if it feels a little loose I know that it’s more then likely a little bowed.
Best Regards,
James
Old 11-30-2010, 09:11 AM
  #609
yokemad's Avatar
I've tried those TIps they worked here
banana effect is gone now Yippie
yokemad is offline
Old 12-01-2010, 05:23 PM
  #610
Blue Screw's Avatar
can someone tellme were i can buy cefx parts at
Blue Screw is offline
Old 12-01-2010, 06:04 PM
  #611
locked's Avatar
http://www.cefxspeedshop.net/page/1r71l/Shopping.html
locked is offline
Old 12-02-2010, 06:44 PM
  #612
haywood's Avatar
Trader Rating: 49 (100%+)
Has any other guys had this chassis issue? Hopefully Josh can give us some info on this problem.
haywood is offline
Old 12-02-2010, 08:58 PM
  #613
Haywood,
"I have found this as well, I only get it if I tap something pretty good.
Best regards,
James"
We have four guys at the local track running the car and these things have taken care of 95% of the problem, hope that helps.
Old 12-03-2010, 07:01 AM
  #614
can someone tell me off the chassis is an improvemend of the photon and what is improved?
toptek is offline
Old 12-06-2010, 10:41 AM
  #615
Hi toptek, first i would like to thank you for your reply on the tekin topic, about the cefx that i'm testing for a month on a large asphalt track here in Rome with medium grip(solaris medium rubber tires) i can say that the improvement over a standard photon is my lap time improved by .5 sec. technically speaking i cannot explain for my poor english, anyway the car is more easy to drive even in low temp. and low grip conditions of the track and is very sensitive in every minimun regulations, the first time i drove the cefx i said "guys this is driving".
thanks to cefx engineering, i'm satisfied with the car, good job.
Hope this helps.
genius120 is offline
