Old 06-23-2010, 11:29 AM   #406
Goingfast's Avatar
Trader Rating: 29 (100%+)
Wish you luck josh...!
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 06-23-2010, 03:30 PM   #407
Luppi Stefano's Avatar
Good luck for WC!!!
Luppi Stefano is offline   Reply With Quote
Old 06-24-2010, 01:58 AM   #408
razzor's Avatar
Good Luck Josh !!!
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-28-2010, 09:13 AM   #409
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Hi
I finally got to run my Evo for the first time outdoor and i'm very please with ths car...Just like MDawson said ...point and drive,,the Car is really fast ...
OVA is offline   Reply With Quote
Old 06-28-2010, 01:23 PM   #410
Trader Rating: 23 (100%+)
The standard Photon setups are complimentary to the CEFX setup. Curious if others are stiffening the chassis or suspension to deal with higher bite in spec classes uses. In mod, it seems to do just fine.
I sent Josh a note to get his perspective on what to attack first, still waitin.
MDawson is offline   Reply With Quote
Old 06-28-2010, 02:23 PM   #411
hana166's Avatar
Interesting, on carpet I could not get the car to work until I used a default T3 setting (nearly) and bingo the car has been wonderful this week, smooth and flowing with good mid corner speed. Been a pleasure to drive.
One problem is the belt unshipped when tapping/glancing a board. The other driver at our club has the same problem. Car has banana like flex due probably to the low position of the top deck, the belt loses tension and hops off. will try fitting a standoff the centre of the car.
Snapped a belt on Friday, I never did this before. Might need to fit a support the other side of the spur gear or manufacture one from steel, there is a lot of flex in that area.
Made a carbon guide for the belt will see if this helps at all.
hana166 is offline   Reply With Quote
Old 06-28-2010, 02:32 PM   #412
oldrcr's Avatar
Trader Rating: 44 (100%+)
Just so you aren't frustrated, that he may not answer right away, he is in Germany for the world championships.
oldrcr is offline   Reply With Quote
Old 06-28-2010, 03:01 PM   #413
That's strange Doug, I ran the car in mod without any guides and had no issues, perhaps it the low friction belts you're running ? I was using standard belts out of the kit.
CPD Racing
chris_dono is offline   Reply With Quote
Old 06-28-2010, 04:22 PM   #414
hana166's Avatar
Hey Chris I've fitted the white belt as I have one spare but it was the black one that snapped. I cannot say why, could easily be a fault in the belt.
Indoors often the car can get a bigger jolt than outdoors. A while back I had the belt come off my T2 over and over until I found a loose top deck screw so I'm guessing the belt's hopping off due to upward flex in the car allowing the belt to loosen under certain conditions. It certainly has more flex in this direction than a conventional design. I haven't actually crashed this car yet, its happening when I glance the boards lightly. Whatever the real cause I hope the guide will work well.
I feel I have a good balanced base setting now which is consistent at three different venues. Right there on the money after only an hour set up time.
Time to switch emphasis back to the driving after a month of experimenting with different cars, this car is definitely quick
Old 06-28-2010, 05:50 PM   #415
OVA
OVA's Avatar
Hi
If you tapping/glancing a board,were you on throttle after you hit?
The would explan why the belt come off.....
I have no issued...
Old 06-28-2010, 05:55 PM   #416
OVA
OVA's Avatar
hi Oldrcr..
I think Mdawson was talking about Josh was suppose to post the new CEFX Evo set up sheet just brfore Josh left to Germany..
Mark D and Josh are really good friend for along time...
Old 07-04-2010, 11:29 PM   #417
Just finishing building my conversion kit. Has anyone encountered bottom of motor scrapping the ground?
cvccsi is offline   Reply With Quote
Old 07-04-2010, 11:39 PM   #418
Official's Avatar
No didn't encounter this issue. Only when i made too much roll in chassis and when the i clip the corners, the bottom corner of the the motor will get scratch, but that happen to me when i use any chassis.
Chassis :4WD = CEFX Photon,TA-05|2WD = Xevo, M05PRO, FF-03Pro, Kysho Evola M3, Kyosho V-One RRR Shimo, Team C TC02
ESC :Brushless - Tekin RS-Pro, Keyence Tachyon|Brushed - Tekin FX-Pro
www.hiro-seiko.com ; www.cefx.net
e-mail: [email protected]
Official is offline   Reply With Quote
Old 07-04-2010, 11:43 PM   #419
Official's Avatar
Congrats to Josh,
Getting Rank #43 at Worlds alone in not an easy task.
Great Job!!!!
http://www.dmc-online.com/wm/livetim...723716/1-10th/
Old 07-05-2010, 12:45 PM   #420
Thanks.
