CEFX 2010 - A new Evolution. >
Old 05-24-2010, 03:01 PM
  #286
F1fletch's Avatar
Exclamation
Looking forward to more feedback and good results from the Reedy Race. Plans have already begun for running an EVO soon so I look forward to buidling and driving this car.
F1fletch is offline
Old 05-24-2010, 10:32 PM
  #287
Official's Avatar
Just finish building my Evo. Build looks goooood!!!!
Can't wait to give it a try later at my local track.
Official is offline
Old 05-25-2010, 12:18 AM
  #288
Trader Rating: 36 (100%+)
All good now, was just the top profile of the servo, spaced it back a little more and now its all good. Wasn't really keen on the double sided tape option.
Originally Posted by MDawson View Post
I am not running the slim servos in my car.
Just an option.
I mounted my servo about 5mm back of the mounting holes to provide more ackerman options. No need to drill holes, just use 3M double sided tape, will hold like a champ.
Originally Posted by $$$... View Post
Hi guys, just putting the finishes touches on my Evo, and I seem to be having some issues with my servo clearing the steering bellcrank. I'm running a Futaba 9551 servo... is this servo too long/thick/tall??? will have to have a closer look in the morning, but any hints or help would be appreciated.
Oh also, Josh, awesome looking machine. Can't wait to hit the track.
$$$... is offline
Old 05-25-2010, 12:59 AM
  #289
XxRONNxX's Avatar
Thumbs up
Ran my EVO last weekend and the weekend before at Norcal Hobbies. "Point and Shoot" describes the car exactly. Didn't spin out or lose control. Turns as quick as a pan car. So quick, I was always slapping the corners too early cause the car turned too quickly. Lots of twist in the chassis which gave the car a ton of steering. Josh, I have a decent asphalt set-up but I'm sure you'll have something better for the Reedy.
The stock Photon is a great car which I feel I can drive more aggressively. However, the EVO is much more stable and turns fast. I'm sure everyone's opinions will differ. If only I was a better driver, I could have had better results last weekend.
XxRONNxX is offline
Old 05-25-2010, 09:08 AM
  #290
Goingfast's Avatar
Trader Rating: 29 (100%+)
I thought the Evo was a little stiffer than Photon,which stable the car more...
Goingfast is offline
Old 05-25-2010, 11:09 AM
  #291
F1fletch's Avatar
This sounds really hopeful, hope it does well at Reedy!
F1fletch is offline
Old 05-25-2010, 11:34 AM
  #292
Josh Cyrul's Avatar
Goingfast - It's stiffer than the origional Photon rubber cars but I'm sure not as stiff as the ones where guys ran the foam 3mm chassis or the new 2.25mm quasi Lipo chassis.
Thanks for all the comments everyone.... Super busy trying to make sure everything is sorted here for Angel while I am at the race but once the madness slows down later tonight I'll try to post a little Pre-Reedy info!!
Thanks again!!
Josh Cyrul is offline
Old 05-25-2010, 11:50 AM
  #293
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
so is the EVO a kit that transfers to the photon?
Ultraspeed84 is offline
Old 05-25-2010, 11:54 AM
  #294
XxRONNxX's Avatar
It probably is a little stiffer. I was trying to get my car to twist a little more for asphalt. The car felt stable regardless.
XxRONNxX is offline
Old 05-25-2010, 12:00 PM
  #295
Goingfast's Avatar
You want more twist for asphlat...Why not run softer spring with no sway bars..
Do you mean more rear end rotating around the corner?
Old 05-25-2010, 01:44 PM
  #296
XxRONNxX's Avatar
Sorry...not twist. I meant more flex.
XxRONNxX is offline
Old 05-25-2010, 05:34 PM
  #297
Trader Rating: 23 (100%+)
Yep comes as a kit with everything to transfer the photon. The new shock towers, and camber plates do not come with the kit.
bmcallister is offline
Old 05-26-2010, 11:00 AM
  #298
F1fletch's Avatar
Why are the different camber plates needed, just to match the CF weave of the other parts (instead of using the Photon Ones)????
F1fletch is offline
Old 05-26-2010, 11:44 AM
  #299
Goingfast's Avatar
I think the camber plate it is a little thicker than the stock one...plus the Evo plate really look nice and does match the chassis.....
I got them all...lol
Old 05-26-2010, 11:57 AM
  #300
heretic's Avatar
I've had the chance to see the Evo conversion that a pal of mine bought along with his photon kit. He's built the car and the result is nice but the manufacturing is far from being as good as expected as far as the CEFX parts are concerned. For instance ther was a BIG "blurr" under the steel motor mount. The guy works as a watchmaker so for him that's no biggie but still , that was a bit disapointing. I am in the process of writing a short review of the build with the pics he took while building, so check www.overrc.com regularly ! it should be ready at the end of the week. The whole site is in French but it's quite easy to translate.
heretic is offline
