CEFX 2010 - A new Evolution. >
Old 05-20-2010, 07:31 PM
  #256
Official's Avatar
Originally Posted by Josh Cyrul View Post
olhipster1 - I have my set-up from the ROAR Carpet Nats but I don't have any for asphalt yet. I can make an estimated guess though and I will work on the set-up sheets specifically for the Evolution.
Hi Josh,
Will this set up work with form tires on?
Official is offline
Old 05-20-2010, 07:42 PM
  #257
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Khador12 View Post
The Speedpower 5300 45c battery does have the bumps. The new 55c batteries do not have bumps.
Goingfast is offline
Old 05-20-2010, 07:53 PM
  #258
Josh Cyrul's Avatar
Official - I don't think it would work with foam tires very well. If you are going to run foam tires, I can work on a best guess estimate for a set-up on foams for the Evolution but what are you running the car on - asphalt or carpet??
Josh Cyrul is offline
Old 05-20-2010, 08:12 PM
  #259
Official's Avatar
Will be running it on carpet, tires commonly used will be 37S forms. Track Layout not out yet. Best if it will be a set-up for technical layout which i can work down from.
Official is offline
Old 05-20-2010, 08:20 PM
  #260
Trader Rating: 21 (100%+)
Josh,
Are you running Tamiya wheel hexes?
Brian L is offline
Old 05-21-2010, 10:06 AM
  #261
Josh Cyrul's Avatar
Brian L - I usually run 4mm wheel hexes (or as close to em as I can get) but it depends on the rims. Normally, we are on Jaco rims at a lot of the races and these have a bigger off-set than say the Tamiya or Solaris rims. I almost always run 4mm hexes with Jaco's and I don't recall the exact difference but I will measure the rims when I get to the Reedy and adjust the hex or spacers accordingly.
Old 05-21-2010, 03:06 PM
  #262
F1fletch's Avatar
Finally got some pics. I mounted the transponder in the front bumper. Has anyone tried this? Is it a bad idea?
Clean looking job!!
F1fletch is offline
Old 05-22-2010, 04:43 AM
  #263
Trader Rating: 26 (100%+)
Josh - Awesome job on the kit - great fit & finish.
Minimalist in the right areas. The motor mount, spur gear set up are smart. Looking forward to getting some mileage on the Top/CEFX this weekend.
Great work.
MDawson is offline
Old 05-22-2010, 10:00 AM
  #264
CARD's Avatar
Clean looking job!!
+1!! Neat!!
CARD is offline
Old 05-23-2010, 12:16 AM
  #265
what do lipo users (without the humps) use to locate the pack in place and affix it in one location? I understand you need to use tape and that is fine but without lipo locating tabs the pack can obviously scoot around a bit...
Hi Josh, can you comment on this? I like to know too. Thanks.
cvccsi is offline
Old 05-23-2010, 07:11 AM
  #266
I installed the TOP lipo balance tray with 1mm of spacing pushing out the tray. It allowed me to locate the lipo pack in a consistent location with option to add more weight. Of course, still using tape. All of my packs are flat.
That will give the pack all four areas to wedge placement.
MDawson is offline
Old 05-23-2010, 12:11 PM
  #267
F1fletch's Avatar
Does this come std as part of the Photon kit?
Pics of it installed on the Evo Please....
F1fletch is offline
Old 05-23-2010, 03:37 PM
  #268
Thanks, MDawson. One more question. What about the other side of the balancing tray, is the battery pushed against the top deck?
Thanks again.
cvccsi is offline
Old 05-23-2010, 04:06 PM
  #269
It does come with std photon.
MDawson is offline
Old 05-23-2010, 04:08 PM
  #270
Thanks again.
There is no real top deck for it to interfere with. The inside rear battery edge sits against the one of the lower stiffener/bulkhead elements.
MDawson is offline
