LRP Quantum World's Upgrage Kit
I run in Stock using a Losi XXX-S with a Quantum Competition II ESC.
Should I be using the LRP Quantum World's Upgrage Kit with this ESC? What are the benefits? Thanks. |
don't NEED it but will give you more punch!
:tire: Some reason I can't find instructions for world's upgrade kit. If I remember right instructions say ecs will fine without one. But capacitor helps when running low turn motor. It also help lower resistance of battries. I have run the competiton without a capacitor in mod (11t) about a year before I put caps on. I'm running 2 big ones, one on a competition and one on a competiton 2. I haven't noticed difference running them. Then again I'm only running one stock motor & one 19t motor right now.
Go buy a cap at your local electronics store, it will be about 2/3 of the LRP price and it's exactly the same performance. Just look so the cap has the same numbers as the LRP speedo.
You dont need the worlds kit, I've been runing a P94, 10x2 pretty hard with my Q2 and havent had a single glitch. Maybe if you get into single digit winds you may want to add one just for protection.
Do a search...there are many detailed threads on this topic in here.
