Old 04-18-2004, 08:13 PM   #1
Cardboard's Avatar
Send a message via AIM to Cardboard
Default mounting foam tires
hey
i'm thinking about using donuts instead of mounted foam tires on my xxxs to save a few bucks. I was looking around on tower at the jaco donuts, and i only saw 33mm tires(listed in the specs column). i assumed that they were 1/10 pan tires. but, when i looked at TRC donuts, which clearly said 26mm in the title, they said 32mm in the specs. what gives? are these tires 26mm or 32mm? and are those jacos on tower 1/10 tc tires or not?
also, can anyone reccommend a good foam tire rim?
thanks
Cardboard is offline   Reply With Quote
Old 04-19-2004, 01:35 PM   #2
Cardboard's Avatar
Old 04-19-2004, 01:45 PM   #3
akrcracer's Avatar
board, check out www.rc4less.com. for dounuts. There are ways for save money. If you want to run 24 mm wheels. You can buy 10 scale rears in compound and get 2 pair out of one dounut. But you would have to cut them.
Or just buy touring car dounuts and mount them yourself. It isn't hard. You can pm me and l'll step you thru it.
akrcracer is offline   Reply With Quote
Old 04-19-2004, 02:13 PM   #4
Cardboard's Avatar
thanks for your help akcracer.
what 24mm rims do you reccommend? do you need specialty foam tire rims? i couldn't find anything on tower or rc4less.
also, is reusing rims possible? just boiling them to crystalize the ca, just like rubber tires?
Old 04-19-2004, 08:24 PM   #5
Mike Haynes's Avatar
The donut is wider then the rim to account for mounting error. After you mount the foam, you would then file it down to the proper width (that of the rim) on a truer.
If it was the same exact width, it would be hard to glue it on straight.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Is mounting tires hard? Ofna_Driver_777 Electric Off-Road 26 01-05-2008 01:09 PM
A new spin on mounting tires? eri3f0g Electric Off-Road 1 09-24-2005 09:12 AM
Foam Tire Mounting Tool? Hyperform Racing Electric On-Road 6 02-20-2005 11:03 AM
Jaco Foam Tires & Fast Tires Foam, Brand new. MugenMTX3Kid R/C Items: For Sale/Trade 11 01-03-2004 01:53 PM
