Best Stock Motor? >
Best Stock Motor?
Best Stock Motor?
Old 04-20-2004, 05:15 AM
  #31
g12314's Avatar
Originally posted by HKlosi
dude i've been racing for a year i need something that'll get me in the A-main in superstock
Made the A-Main at the Trophy race with a Monster geared at a final drive ratio of 8.06
The radio glitching Demons made sure I didnt finish it however .
Jimmy
g12314 is offline
Old 04-20-2004, 09:10 AM
  #32
Default best stock motor?
Is one that will handle heat... Ive tried alot of motors and just cant seem to find a stock motor that wont burn up during its use ..I then switched to 19t and mod and no burning motors at the track... whats up with that ????? .. anyway I did like the monstor stock's very good tourq, and speed .. when i didnt smoke it .....
mb racer is offline
Old 04-20-2004, 09:23 AM
  #33
Trader Rating: 70 (100%+)
MB racer.If you will take a Orion Core or Peak Hellfire and drill a hole in the - side brush with an exacto and then narrow the face of each brush like BiG Jim states these motor's will outlast the arm.The magnet's are 10x's the quality of trinity.
The New Integy Atlas stocks and Reedy MVP's are the same way.Just a lil more tuning but on tracks that dont have a HUGE straight they rock.Expecially on smaller tigher to medium sized tracks.
TexRacer is offline
Old 04-20-2004, 10:58 AM
  #34
Default stock motor very inefficient
stock motors used to be very reliable, slow and efficient.
But nowadays people want higher speeds, so you have a trade
off, high speed, low efficency and higher heat. If you want a
cooler running stock motor try a SIB motor.
rcfaster is offline
Old 04-20-2004, 03:04 PM
  #35
Default TEX
believe me Ive been through them all and all have the same effect to me ... Some do hold up a few runs better than others but I dont have the problems with 19t or mod, so ill stay with them and just keep going fast ... Our layouts are pretty dialed in to be fast and the straights are long for stock but the racing is all fast and clean.. Thanks for the tips if iever go back to stock ill try a few things ..
mb racer is offline
Old 04-20-2004, 03:58 PM
  #36
Cool nothing beat an SIB
we have spent years of [email protected] to provide you with the finest
electric motor.
rcfaster is offline
Old 04-20-2004, 04:14 PM
  #37
nashrcracer's Avatar
if you heard Big Jim talk about it yes the MVP is the way to go just gear it to the roof. well the higher you gear the more punch you lose. I run a monster stock with very little prep and it just runs and runs and runs. As for the BS quad mag motor it isn't as efficient as the monster but runs about the same wattage on my fantom. I run 12th scale so efficiency counts. I gear the monster the same and maybe one tooth higher then the BS and even with that I can dump the BS motor if I don't baby it for the first two minutes. I could never get a core to run right. the P2K2 doesn't have the punch as the monster nor the top end without gearing high.
AND WHY DO STOCK MOTORS STILL HAVE BUSHINGS!
nashrcracer is offline
Old 04-20-2004, 04:52 PM
  #38
edseb's Avatar
The original idea for stock was a class to keep costs down, hense the bushings instead of bearings. That concept has been tweaked since it costs a lot to run stock competitively.
edseb is offline
Old 04-20-2004, 05:17 PM
  #39
HK Racing Joe's Avatar
thanx
HK Racing Joe is offline
Old 04-20-2004, 05:41 PM
  #40
Cool pk2
The days of the pk2 and the Race prep are over. The new dual
stack armatures produce high end power, low end torque, but win
in the long run. Do not overgear these fine machines. SIB
rcfaster is offline
Old 04-20-2004, 06:42 PM
  #41
Trader Rating: 17 (100%+)
i blew up my monster at the track this week and instaled a p2k2 tweked it alittle and it turned better lap times then my monsters ever did, and this is on a huge track with 10 foot lanes, carpet indoor
Kave is offline
Old 04-20-2004, 06:44 PM
  #42
Trader Rating: 14 (100%+)
monster stock pro is the best
HEWITT is offline
Old 04-21-2004, 12:41 AM
  #43
asimo's Avatar
Quick question regarding the Monster Pro and P2K2.
What is the gearing range for both motors? (final drive)
Monster Pro?
P2K2?
asimo is offline
Old 04-21-2004, 01:29 AM
  #44
Yokomo Aust's Avatar
Default Best of the best
I run a Monter stock. This has to be the best motor. Pleanty or torque and high rpms. Just pick the motor tuner for eg. Jim or Putnam there are quite a few. Does not like to be over geared. Back it up with some Fukuyama matched cells and you will never look back.
Yokomo Aust is offline
