Old 03-30-2010, 03:03 PM   #1
Norman2's Avatar
Default Removing glued tires from plastic rims
Hi, How do you remove glued tires with inserts from plastic rims? Thanks
for any help.
Norman2
PS. I think they are glued with CA tire glue
Norman2 is offline   Reply With Quote
Old 03-30-2010, 03:05 PM   #2
Cappy's Avatar
Trader Rating: 14 (100%+)
Ive heard alot of people putting them in the oven on na old baking sheet for a bit but I havnt tried it yet. Just gotta be carefull not to leave em in there too long
Tekno EB48.3 RX8 Gen2 T8 1900 19T..
Tekno ET48.3 RX8 Gen 3 T8 2000
Tekno |Sweep | Dialed Inc | Boca Bearings | Mels Shells
SLOW THE F%&# DOWN so you can go fast !!!
Cappy is offline   Reply With Quote
Old 03-30-2010, 03:07 PM   #3
Norman2's Avatar
Thanks, will give it a try
Norman2
Old 03-30-2010, 03:11 PM   #4
c-lyon's Avatar
I've only done it with offroad tires. AFTER cooking supper at 350*f, switch off the oven and put in the tires (I just put them on the rack), and after about 20 or 30 minutes they should just snap off. If not, dunking in cold water should complete the job. There is a bit of an odour for a short while.
c-lyon is offline   Reply With Quote
Old 03-30-2010, 04:23 PM   #5
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Some of the guys at my track advice is to boil them for 30-50 minutes..
This also is ment to break down the glue...
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 03-30-2010, 04:47 PM   #6
Norman2's Avatar
Hi, Thanks for your help. I am sure one will work.
Norman2
Old 03-30-2010, 05:24 PM   #7
C&B RC's Avatar
cut the bulk of the tire off. Put the rims in a coffee can and soak in acetone overnight covered. What is left on the rims just falls off by morning. The rims come out pristine. Not sure about chromes though.
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 03-30-2010, 05:54 PM   #8
trerc's Avatar
Trader Rating: 89 (100%+)
Just do the baking method it's the quick and not a pain in the ass like the other methods of tire removal.
Set the oven to 300 place tires on a cookie sheet (foil covered) and start to watch them after 8 min or so, it will take 8-15 minutes to get the tires off, most of the glue will come loose the glue that doesn't comes off easily tho. I use a wire wheel on Dremel to prep them before remounting.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 03-30-2010, 06:14 PM   #9
volracer's Avatar
Send a message via ICQ to volracer
This is what I did when I raced 1/8th scale nitro. I used rims several times. Just use gloves because acetone is a carcnegen.
volracer is offline   Reply With Quote
Old 03-30-2010, 06:40 PM   #10
Default oven the tire
i had to remove tires from my rims. first tried the boil method worked but the foam and tire still stuck. got my next set of tires and did the oven. 350 on an old cookie sheet about 8 to 10 min check after 6min. the tires just popped right off the rim. good luck
PMHOURS is offline   Reply With Quote
Old 03-30-2010, 07:34 PM   #11
geeunit1014's Avatar
Does the oven method harm the tire? I have some tires mounted up that have the wrong insert in them, and id like to change the insert and not spend $40 on a new set of Tamiya tires.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 03-30-2010, 07:43 PM   #12
trerc's Avatar
The tires are usually very soft and tear when you remove them. I doubt you could salvage them, I could be wrong tho. Not to mention most of the glue stays on the tire...
Old 03-30-2010, 07:43 PM   #13
Cappy's Avatar
Its not supposed to as long as you dont heat too high for too long.
Old 03-31-2010, 12:37 AM   #14
acetone is the best method. rims come out pristine as mentioned before and it's completely effortless.
You don't even have to submerge the entire rim, just soak them a bit in the acetone and leave them overnight inside a metal or glass container (a cookie jar for example), you don't need to use much acetone (a cup will do). As long as the container is sealed the vapors from the acetone will do the job of dissolving the glue.
I've tried the bake method before and its not for all types of rims/glues...
Rufus2000 is offline   Reply With Quote
Old 03-31-2010, 01:07 AM   #15
Trader Rating: 22 (100%+)
Acetone only works with nylon rims. If yours are plastic they will melt and you will be left with a plastic sludge. Mind you, if your rims are plastic throw them away and buy nylon.
I use the oven method.
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
TIRE GLUEING TECHNIQUES JonnyW Nitro Off-Road 59 04-23-2012 09:30 PM
Removing glued tyres sperera Nitro Off-Road 50 05-03-2010 03:25 PM
