Glitching Monster >
Glitching Monster
Glitching Monster
Old 04-16-2004, 11:10 PM
rod_b's Avatar
Default Glitching Monster
I have a Monster Stock that is glitching really badly. I don't have glitching probs with my other motors. A friend suggested that the surface mounted caps are bad. Do I just solder on some new caps or do I have to take the SMCs out first?
rod_b is offline
Old 04-16-2004, 11:14 PM
I had the same problem.....I just put it in a toolbox for a few months then took it out and put a new endbell on it when another monster's arm burned up.
The Black Kat is offline
Old 04-17-2004, 05:27 AM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
don't add any caps.
I had the samething hapen.
RESOLDER the caps on it along with solder the wires coming off the circuit board going to the screw.
Hope that made since..
I can take a pic if needed.
Tres is offline
Old 04-17-2004, 02:01 PM
DaveW's Avatar
I had the same problem. The motor slowed excessively and glitched like heck. I too tossed it in the toolbox... its still there.
- DaveW
DaveW is offline
Old 04-17-2004, 08:39 PM
DT-Skyline's Avatar
Could be brushes, endbell, arm, or just needs a capacitar.
DT-Skyline is offline
Old 04-17-2004, 09:19 PM
fatdoggy's Avatar
If you can't get it fixed just rip out the SM caps and solder on some more. Of course then you have to spend ages re-aligning the brushes(if you do it).
fatdoggy is offline
Old 04-17-2004, 09:20 PM
popsracer's Avatar
Rod_b;
Hey, you might have a Bad Cap on the circuit board. Try what 'Tres' suggested. If that doesn't work, you can buy replacement Boards seperately.
That or remove the Board and just solder on 3 regular caps like the old days.
popsracer is offline
Old 04-18-2004, 08:29 AM
HK Racing Joe's Avatar
get your comm turned and new brushes i had the same problem and that fixed it
HK Racing Joe is offline
