Old 03-19-2002, 02:36 PM   #1
Default XXX-S threaded shocks
I bought the .28 threaded front shocks, #LOS5052 and the .36 threaded rear shcoks, #LOS5053 from Stormer and had a question acout what I got. The fronts came with the short threaded tubes, nuts and the caps. The rears only came with the threaded tubes and the nuts. Was I supposed to get the shafts with each of these sets aand also the caps for the rear shocks or is this right?
Also, do I need to run the shorter .28 shock shafts in the front .28 threaded tubes? I currently have the stock shafts in both the front and rear.
Thanks for any help,
Rob
R_Andersen is offline   Reply With Quote
Old 03-19-2002, 04:19 PM   #2
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
You got what you ordered...
If you wanted the whole kit, you should have ordered the LOS5058 for the front. That comes with the shafts and everything. For the rear... just use the shafts and caps from your stock shocks.
ChristopherKee
ChristopherKee is offline   Reply With Quote
Old 03-19-2002, 04:59 PM   #3
Ok, thanks. So now I assume I need to buy the .28 shafts for the front shocks for them to work properly?
Old 03-19-2002, 08:55 PM   #4
That is correct, you need the short shock shafts for the front only. It would have been better to order the entire kit mentioned above, but you can still get the parts needed.
Flash
Flash is offline   Reply With Quote
Old 03-20-2002, 05:55 PM   #5
DennisNyholm's Avatar
Default LOS5058???
I just looked on stormer and LOS5058 is the titanium shock shaft .28. It isn't the entire kit unless the whole hit costs 5.95!!! What is the correct part number for the front threaded shock kit with the shafts? THanks a lot.
DennisNyholm is offline   Reply With Quote
Old 03-21-2002, 03:23 AM   #6
Regional Moderator
Addict sa RC's Avatar
A-5081
Addict sa RC is offline   Reply With Quote
Old 03-21-2002, 08:06 AM   #7
I was using the part numbers from horizonhobby... since they are the only distributor of Losi parts...
Old 03-21-2002, 10:36 AM   #8
Thanks a lot for the part number. $24.95 sounds more like the price!!!
WTB: Threaded TC3 Shocks BOSS-2 R/C Items: Wanted to Buy 0 02-20-2008 08:32 PM
Threaded shocks... Herrcomestroubl R/C Items: Wanted to Buy 0 09-16-2007 04:27 PM
looking for t4 threaded shocks calstarjig90j Other Items: For Sale/Trade or Wanted to Buy 0 02-17-2006 07:07 PM
FS--> HB threaded shocks Elk666 R/C Items: For Sale/Trade 6 03-16-2004 08:50 AM
Threaded shocks for 35??? doublest Electric On-Road 1 05-09-2003 01:28 PM
