Old 03-28-2010, 07:15 AM   #1
Default TC5R vs TC5F
Whats the difference?
All i know the only difference is R runs the thinner ITF Upper & Lower Deck.
LiL_JaSoN is offline   Reply With Quote
Old 03-28-2010, 07:30 AM   #2
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I think the F comes with a diff an d the R has a spool. Also the out of the box set ups are for their intended purposes. R has springs for rubber tire racing the F has stiffer springs, etc.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 03-28-2010, 11:40 AM   #3
Tubaboy's Avatar
The F also has the "Hard" plastic parts for arms, steering blocks, and camberblocks.
Although, I like to use them on my rubber setup as well.
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 03-28-2010, 08:23 PM   #4
cool, just wondering if i came across a cheap F.
i could just get the upper IT deck ($20) and a front spool.
Old 03-29-2010, 04:50 AM   #5
R comes with enough parts to build a front diff or slipper spool.
To convert the F diff to slipper spool all you'd need to get would be the slipper pads. Just take out the diff balls and put the pads on the outdrives instead of the diff rings and you're good to go.
If you were to get the F cheap and you want to go R take a look at the Exotek chassis and upper deck rather than buying stock ITF parts.
As was mentioned before the R comes with all soft suspension components. Essentially the same suspension parts (arms, hubs, steering arms, etc) that come with the old Factory Team version.
spongerX is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
TC5 vs. TC5r trdsupra88 Electric On-Road 17 05-07-2009 10:45 PM
TC5 and TC5R iLL-Mitch Electric On-Road 8 12-14-2008 04:29 PM
