Lrp Runner
Old 04-14-2004, 11:37 PM
Default Lrp Runner
Can a LRP Runner Plus reverse take modified motors?
LancerEVO is offline
Old 04-15-2004, 12:17 AM
WC
WC's Avatar
Trader Rating: 28 (100%+)
Mild mods down to about 15t should be OK I think.
The LRPs have a temp cutoff protection so if they're overheated
they'll just shutdown. If it shuts down frequently then that's
when you should take the hint that your motor's too hot.
WC is offline
Old 04-15-2004, 12:18 AM
i looked on the team associated website and they said it was able to hold a 17 turn stock
Old 04-15-2004, 12:58 AM
WC
WC's Avatar
ya, sounds about right. I was going by the LRP Sprinter's specs.
There's no such thing as a 17t stock.
"Stock" means 27t (23t in Japan) with unchangeable timing, the rules are very clear.
Everything that's not a stock, is a Mod.
WC is offline
Old 04-15-2004, 01:33 AM
but can the runner support modified motors and if so how mant turns
Old 04-15-2004, 01:45 AM
Java1970's Avatar
If Associated said the lowest you can run with that ESC is a 17 turn motor, that IS a modified motor and 17 turns is as low as you can go without damaging the ESC. ANY motor with less than 27 turns is concidered "modified". Hope this helps.
Java1970 is offline
Old 04-15-2004, 10:49 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
You may want an ESC that has brakes on it. From what I understand the runner doesn't.
Cain is offline
Old 04-15-2004, 12:38 PM
Java1970's Avatar
If it came stock with the RTR TC3, it has no brakes, you have to be careful with the trigger and use the reverse as brakes.
Java1970 is offline
Old 04-15-2004, 03:39 PM
actualy it does have brakes
Old 04-15-2004, 07:48 PM
Moderator
Cmotif's Avatar
I was just given a LRP Runner for our club in very Northern California. I would like to be able to get it into a car for a new racer on the 24th of this month. My question is, how does one set up a LRP Runner?
Is there anyway to turn off the reverse?
Cmotif <><
Cmotif is offline
Old 04-15-2004, 08:44 PM
No. you cannot take off the reverse and i think its already preset
Old 04-16-2004, 05:55 PM
Moderator
Cmotif's Avatar
Can some one please tell me how to set up a LRP runner? Too bad that the reverse can't be turned off.
I know how to set up other ESCs, but I do not know how set up a runner.
Cmotif <><
Cmotif is offline
Old 04-16-2004, 09:40 PM
ITS ALREADY SET
Old 04-16-2004, 10:17 PM
DT-Skyline's Avatar
Lancer, it depends on how much that ESC can handle. If it has a motor limit of 15T, u can use up to 15T modified motors. Anything over that, it can't handle. If u use an LRP IPC 7.1 which has no motor limit, u can use any motor out there today.
Mini NAte
DT-Skyline is offline
Old 04-16-2004, 10:33 PM
