What 27 Mhz AM Receivers work with Kyosho Perfex radio? >
Old 04-14-2004, 02:48 PM
Moderator
Cmotif's Avatar
Default What 27 Mhz AM Receivers work with Kyosho Perfex radio?
Here is the deal, I'm helping some new people get involved with the sport. Where we are located in Northern California (Weed, CA) we can end up with snow or rain at any time.
So the plan for the club is race outside when it is nice with 1/10th scale and race inside with Mini-zs when the weather is bad.
So as I am helping people get started, I am trying to save them the trouble of having multiple radios. I need to know what AM 27 Receiver can go in a 1/10 TC and will work a Kyosho Perfex radio.
I just don't want there to be compatiblity problems. The Kyosho Perfex radio is what comes with Mini-z cars.
Are the crystals interchangeable between Kyosho, Airtronics, Futaba etc? It is a tough question, and they is why I came to the most knowledgeable group of RC users on the web!
Cmotif <><
Cmotif is offline
Old 04-14-2004, 03:33 PM
fabolousRC's Avatar
if I'm not mistaken the perfect radio is compatible with futaba. I'm not 100% sure but the ones for the RTR Alpha series, the servo plug is exactly the same as futaba's
fabolousRC is offline
Old 04-14-2004, 05:09 PM
Moderator
Cmotif's Avatar
I was just given (since I posted this thread today) an Airtronics 27 Mhz receiver today. Is there going to be compatible issues?
Cmotif <><
Cmotif is offline
Old 04-14-2004, 05:34 PM
fabolousRC's Avatar
yeah...If I'm not mistaken Airtronics/JR/KO are negative and the Futaba/Hitec positive shift crystals. That's why Hitec makes a Dual Conversion receiver in order the user to be able to use different type of transmitter without being tied down to just same manufacturer's receiver.
Hopefully someone can confirm me on Perfect being Futaba based. If there is another reason why i would say that is because Futaba and Kyosho are under the same distributor in the US: Great Planes.
Old 04-14-2004, 05:56 PM
WC
WC's Avatar
Trader Rating: 28 (100%+)
The Kyosho Perfex is an AM 27MHz radio, there's no
issues with +ve/-ve shifts and all that jazz.
Kyosho has rebranded other manufacturer's TXes. There are 2
versions... the older "skewed" 1st one is an Acoms Technisport
(aka JR Panther). The current 2nd "upright" model is what was
sold as the KO EX9 many years ago. These are both simple AM
entry-level radio sets.
Any brand's AM 27MHz receivers will work just fine.
(the Acoms has servo reverse switches, dunno about the KO)
One issue you might want to watch out for is cost.
Price of buying a RX + 2 servos is usually dearer than buying
a full basic stick radio set eg Futaba Attack. I would usually
recommend buying the stick set then using your wheel TX.
WC is offline
Old 04-14-2004, 05:58 PM
I'm actually using a Kyosho Perfex Radio(I believe these are made by KO) with an old Futaba Receiver, no problems.
I was always led to believe there were not the compatability problems with 27mhz am as there are with the 75 band.
Just my experience...
bainfowler is offline
Old 04-14-2004, 06:08 PM
WC
WC's Avatar
Originally posted by fabolousRC
...Futaba and Kyosho are under the same distributor in the US: Great Planes.
So what? US distributor rules the world??
Kyosho are under the banner of the Asahi conglomerate, entirely Japan based. Asahi also does a tonne of other things, including
brewing a decent beer or 3.
Acoms is also another Asahi company.
WC is offline
Old 04-14-2004, 06:16 PM
WC
WC's Avatar
Default Re: What 27 Mhz AM Receivers work with Kyosho Perfex radio?
I think the 1st version came with everything up until recently,
and the MR-02 MiniZ came with the 2nd version.
Yep. AM 27MHz xtals have no inter-compatibility issues at all.
Keep everything AM & on the 27MHz band and there will be no dramas.
btw there are only 6 main freqs in the 27Mhz band (26.995-27.255).
Modern gear has "splits" which adds another 6 (7?) freqs, but
sometimes these can cause and/or receive interference from
others on a nearby freq.
Interference will be more pronounced when you use mixedbag
radiogear and some older radiogear aren't very narrowband.
If you experience glitching and interference, stick to the main 6 channels.
WC is offline
Old 04-14-2004, 06:47 PM
Moderator
Cmotif's Avatar
So that sounds like good news. Since I have servos already, and have assorted 27 crystals, airtronics RX, and a Perfex radio, then it sounds like we are good to go.
Awesome.
Thanks, sounds like one more person will be able to race with us the 24th!
Cmotif <><
Cmotif is offline
Old 04-15-2004, 03:28 AM
fabolousRC's Avatar
But the guy is from the US, so in the US, Great Planes control everything, Kapisch?
Whatever happens outside America is completely on Kyosho Hands and yes I wish Kyosho do the same thing here in America too, look at Tamiya's success here
Old 04-15-2004, 05:21 AM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
ALL brands 27MHz AM will work together....
No issues with shift...
FYI: Radio Shack X-Mods x'tals will work also.
15.95 for a COMPLETE set of 6.(Rx & Tx)
Tres is offline
Old 04-15-2004, 10:00 AM
Moderator
Cmotif's Avatar
You have got to love Radio Shack for that. What do people know about X-mods, cool or crud? That is good to know that they can at least run on different channels. I was wonder if Radio Shack was going to do the old thing, where you could buy the two different colors of cars and one would be set at 27 and the other 49.
Cmotif <><
Cmotif is offline
Old 04-15-2004, 12:09 PM
fabolousRC's Avatar
it has an available 4wd option...can't beat that!
Just that it's top heavy though (High center of gravity)
