Old 03-22-2010, 11:23 AM   #16
kvnjnsn's Avatar
Trader Rating: 23 (96%+)
Consider what minimum wage is in your state and then multiply that amount by the time it will take you to remove the paint off of the $25.00 body.
If those amounts are even close, bite the bullet and buy a new one.
Nothing worse than a hack job rolling around the track
kvnjnsn is offline   Reply With Quote
Old 03-22-2010, 11:27 AM   #17
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by iPearl View Post
http://formuladrc.forumotion.com/pos...=editpost&p=82
Its pretty simple, as long as you painted it with Lexan Style paint.
-Buy some DOT3 brake fluid,
-Grab a container large enough to hold your body, and round up some paper towels.
(Suggested by another forum the paper towels works the best).
-Place the body in the container and pour some brake fluid in to coat the body.
-Next wad up a couple paper towels, soak them in the fluid, and place them in the body so that they contact most of the painted surfaces.
-Pour a little more brake fluid in for good measure, and go watch the Speed Channel for 15-20min.
-When you get back, the paint should be soft enough to scrape away with the paper towel.
-Rinse it every now and then with warm water to clean the loose paint away, and resoak the body with brake fluid to continue.
-The results are surprising, and the body didn't cloud up.
(This Tutorials was borrowed from Groovy and DRC1)
Wow! I have a couple of bodies at home I have FUBAR'd. I may try this.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 03-22-2010, 11:27 AM   #18
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
well in my case if ur not gonna use that old jug of nitro. u can throw the body in and let it do its thing. come back and see ur results. dish soap it off when ur satisfied to remove the oils that come with the fuel. and ur set. way to go with the old bodies for sure, brake fluid is just too much of a risk for those. but BF does work great too as u can see above.
pick ur poison (literally)
R
UltegraSTI is offline   Reply With Quote
Old 03-22-2010, 11:30 AM   #19
Old Tech's Avatar
I bought a use Tamiya F-1 car. The body was green and white...no idea what brand of paint was used. I didn't care for the colors and the body was pretty tattered so I bought a new one. I decided not to toss out the original body to try some of the paint removal techniques I had heard about. I tried 99% isoporpyl alcohol...soaked a few sections at a time. This worked great on the white, but barely softened the green. I found som grafitti removal spray at my local Home Depot...I can get the brand if interested. This worked on the green. End result, all the paint off, no staining, and I ended up re-painting the body.
Old Tech is offline   Reply With Quote
Old 03-22-2010, 11:49 AM   #20
Thanks everyone for the ideas. I found a great method.............decals. A few decals placed in the correct spot and my body looks a lot better.
storytyme is offline   Reply With Quote
Old 03-22-2010, 01:10 PM   #21
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
Default DECAL/WRAP/Meh Fail Body
I have failed at painting my test BMW body LOL.
So i have decided to turn it into a "RC Car Wrap Guinea Pig"
So yeah STICKER way would be this.
Here are the Result of a failure:
(I never Took Pics when it was done so so all i have are pics after Bashing it LOL)
Pics Loading...
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 03-22-2010, 03:14 PM   #22
RC MARKET's Avatar
Tamiya #87118
http://rcmarket.com.hk/product_info....tfegus74tcq613
RC MARKET is offline   Reply With Quote
Old 03-22-2010, 03:22 PM   #23
Tread1's Avatar
Trader Rating: 18 (100%+)
WOW is there a thread in this forum you Won't pimp your stuff in?
"If you just want to bitch well, feel free to post here on RC Tech and look like the other 95% of the illiterate posts that are written here."---- ROAR ExCom member
Since when does 0=9?
Tread1 is offline   Reply With Quote
Old 03-23-2010, 02:59 AM   #24
iPearl's Avatar
Such a hater LOL.
Not my fault i dont own a Airbrush yet LOL and the Rattle can went blah on me LOL
So you gotta improvise with stickers LOL
In my case it was a HUGE sticker ROFL
Old 03-23-2010, 11:44 AM   #25
I ended up using the brake fluid for just part of the body that I messed up. It worked great. It would take some good effort to do the whole body though.
removing old paint or bad paint from a body? tradhunt Painting, Designs, Graphics and Photography 11 01-12-2007 08:27 PM
Electric On-Road have too many classes? or8ital Electric On-Road 46 10-03-2006 06:13 PM
Foams thread fatdoggy Electric On-Road 115 09-29-2003 05:13 PM
