Old 03-18-2002, 05:22 PM   #1
Default Problems
Heres the problem my car battery is only 2000 mAh and when i turn on the car and give it some throtle the tires will spin and then slow way down and come to a stop then the motor just makes a low squeeling sound like any motor does when the wheels are hung up. Do you think the battery is just done for?
bigbadbullerboy is offline   Reply With Quote
Old 03-18-2002, 05:23 PM   #2
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
How long did it take the battery to peak, and what amp rate did you charge at?
Speedo is offline   Reply With Quote
Old 03-18-2002, 05:33 PM   #3
i don't know what it peaked at but i think it is charging at 1 amp or somthin like that
Old 03-18-2002, 05:36 PM   #4
Moderator
Speedo's Avatar
1 amp is a little low, you could try bumping it up to 4. What I meant is, how much time (minutes, hours, etc) it took to charge.
Old 03-18-2002, 05:44 PM   #5
Ok the charger is a hobbico 900 and it says one amp up by where you put in the fuse it says one and it is a 15 minute charger.
Old 03-18-2002, 06:49 PM   #6
benraldo the ho's Avatar
Send a message via AIM to benraldo the ho
Are you sure the motor isn't hung up? Bad brushes? Grime in motor?
Just a thought
benraldo the ho is offline   Reply With Quote
Old 03-18-2002, 07:29 PM   #7
Moderator
Speedo's Avatar
Yep, try cleaning out the motor. Also, 15 minutes at 1 amp isn't even close to a quarter charge.
Speedo
Old 03-19-2002, 08:40 AM   #8
I am gonna go in and get my motor cleaned out my a guy I know that does a good job cleaning them out then I will pbobably just buy like a 3000 mAh battery.
Old 03-19-2002, 11:15 AM   #9
Regional Moderator
Send a message via AIM to Mike F
before buying a new battery, charge it at 4 - 4.5 amps and see what happens.
2000 packs can be charged up to three times it's capacity but it's recommended that you charge it 2x it's capacity, 2000, charge at 2.00 amps, 4.00 amps or 6.00 amps
Mike F is offline   Reply With Quote
Old 03-19-2002, 11:34 AM   #10
When I first got started in RC, I had the same charger. I usually just charged it for 30mins and it seemed to last alright. But, if you do that, keep feeling the pack for any heat. If it starts getting warm, stop charging it because it's done.
That charger won't work with 3000 NiMH packs. Instead of buying a 3000, get a peak detection charger. You can get a Mega Peak for around $35. I used to have one of those, too. Never had a problem with it, then I got my Tekin BC112c, and now a Turbo 35.
JeffC is online now   Reply With Quote
Old 03-19-2002, 04:42 PM   #11
Toup the amps i just have to buy a bigger amp right. And since I only have 1 amp can i just restart the charge again or not..
Old 03-19-2002, 04:54 PM   #12
Regional Moderator
Darkseid's Avatar
Hey bigbad...: That 1 amp that you see up by the fuse probably isn't what the charger is charging at, thats probably the rating of the fuse, so you know what to replace it with incase it blows. I know, back in the day, I had a charger similar to the one you have.
Check the charger manual or the company website to see what amp rate the charger charges at. For that type of charger, its probably 4amps.
TLR 22...Tamiya F104...
Old 03-19-2002, 07:29 PM   #13
Bigbad - that 1A is not the charge rate, it is the type of fuse that is in there. I have a few of those chargers. I found that the optiumum time to charge a 2000 pack on one of those was at least 30 minutes, maybe 35 if needed. Try that.
Modena AL is offline   Reply With Quote
b4/t4 problems trdsupra88 Electric Off-Road 12 03-15-2008 10:52 PM
JR Z-1 Problems...need help! pumpkinfish Radio and Electronics 3 10-24-2007 05:31 PM
Problems.. Oasis Chat Lounge 9 01-16-2006 08:41 AM
tc3 one way problems dontfeelcold Australian Racing 7 12-31-2003 04:34 PM
Set Up Problems Griz Australian Racing 5 12-05-2003 12:44 AM
