Tamiya TB-Evolution IV >
Old 08-20-2004, 07:10 AM
  #1126
Turbonium's Avatar
Trader Rating: 27 (100%+)
mine spins fo-eva... sprayed out the bearings and relubed with Acer Sin oil.
Turbonium is offline
Old 08-20-2004, 08:57 AM
  #1127
F. Alonso's Avatar
with everything installed but not having the motor attached to the spur gear???
F. Alonso is offline
Old 08-20-2004, 09:12 AM
  #1128
rtypec's Avatar
Default Re: EVO IV
Originally posted by Martin Crisp
Well I finnaly got my EVO IV a couple of days ago. Wow the drive train spins forever...! It will easily spin for 20+ seconds.
Mine spun for a very long time as well. I was concerned how it would hold to a very low wind motor until I ran it in the KO race. Grabbed fistfulls of throttle all weekend and no skipping teeth. It's a pretty fool-proof drivetrain.
JDM-Dave, here's a purposely blurred out photo of DJ's rear suspension from the KO race.
rtypec is offline
Old 08-20-2004, 09:33 AM
  #1129
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: EVO IV
Rod you are just wrong in the head BTW what did you blur out..??that pic for the "DAWG" Bones
PM me if you have some goodies
-Dave
JDM_DOHC_SiR is offline
Old 08-20-2004, 09:36 AM
  #1130
rtypec's Avatar
I'm sure that someone will take a picture of it at the pre-worlds. After that cat is out of the bag, I'll post the un-blurred "mad science" version
rtypec is offline
Old 08-20-2004, 10:29 AM
  #1131
That car has just got the front end of a Evo 4 on the back. Rick
Rick Draper is offline
Old 08-20-2004, 10:58 AM
  #1132
racer's Avatar
i have seen online a rear end conversion from a Pro 4 on the Evo IV and also using Xenon rear hubs.
oh, yeah...if anyone haven't seen it yet. the Kai version of the Evo IV is posted on their site
racer is offline
Old 08-20-2004, 01:59 PM
  #1133
FW-05RR's Avatar
Although I don't own an Evo IV personally I must admit on my friends Evo IV's the drivetrain just spins for eva!!
I love it
FW-05RR is offline
Old 08-21-2004, 12:17 PM
  #1134
WC
WC's Avatar
Trader Rating: 28 (100%+)
Originally posted by KilRuf
...ended up breaking one of my main shaft cups.
Man, why are the slots in the shaft cups cut so deep?
Its not as if that dogbone is gunna go thru severe angles
like a steering knuckle. Tamiya could have cut less of a slot
and left more meat to clasp the 2 cup sides better.
WC is offline
Old 08-21-2004, 03:42 PM
  #1135
forty6's Avatar
Default Re: Re: Re: EVO IV
Is that what the top secret stuff is? Just front susp mounted at the rear?
forty6 is offline
Old 08-21-2004, 08:58 PM
  #1136
JimmyMac's Avatar
I dunno WC. Maybe so you can slide the shaft forward or back to take off the other end of the car or input shaft. But I do know the ring around the cup has worked great for me so far. So I'll deal with that for now.
Question Dave... have you used the Pro4 stuff yet on your car? I was wondering if you could just use the HPI front spindles with the stock Evo IV carriers up front. I'd like something beefier (bearings) up front along with the HPI/MIP CVDs. OH and about the bumpers... any chance on just getting only 1? I think 4 are abit too pricey for me....
Anyways, ran the Evo IV today in 19t and stock. Car ran pretty good for 19t. But it's still not up to speed yet with my Yokomo in Stock. So more tuning should provide better results. Especially considering I had my Yok since it came out. We'll see.
JimmyMac is offline
Old 08-21-2004, 09:07 PM
  #1137
rtypec's Avatar
Default Re: Re: Re: Re: EVO IV
Pretty much
rtypec is offline
Old 08-21-2004, 10:27 PM
  #1138
JimmyMac's Avatar
For those that can't find the Kai conversion... http://www.kmodels-kai.com/index1.htm
JimmyMac is offline
Old 08-22-2004, 04:34 AM
  #1139
Yes the HPI knuckle can be used up front with stock c-huball you have to do is add a .5mm shim and use the TC-3 dog bone works great also same for the rear..you can use the Pro4 rear hub
also no problem on the bumper plate...PM me for more details
-Dave
Old 08-22-2004, 10:00 AM
  #1140
-Dave
u need different bearings if u want to use tamiya shafts.
u can change the bearings and use the evo3 axles.
trf racer is offline
