Tamiya TB-Evolution IV >
Old 08-16-2004, 04:53 PM
  #1096
hawker's Avatar
Originally posted by alan1467
Can anyone translate this page from Tamiya?
http://www.tamiya.com/japan/info/040816.htm
It looks like a problem on 46mm shafts, but I could be wrong
Here is a translation, looks like it just can't be used with the 415.
__________________________________
TB evolution IV 46mm swing shaft (Item 51092)
About oral paper declared correction
Presently while selling is "the TB evolution IV 46mm swing shaft (Item 51092)" concerning, there is "the TB-EVO. IV" "TRF415 lightweight reversible suspension set" and 2 points in the application product which is inscribed in the oral paper, but really the fact that it is applicable is "TB-EVO. IV" only. You cannot use for "TRF415 lightweight reversible suspension set". The apology and also you correct. We applying annoyance, excuse it was not.
_______________________________________
hawker is offline
Old 08-16-2004, 04:59 PM
  #1097
Team EAM
Trader Rating: 79 (100%+)
Yes I ran the car this weekend...Time was mostly spent on the xray though. I only got 2 battery packs of practice with the Evo4 but it was pretty darn good right out of the box. Easier to drive than the xray and faster in the heat. At night I think they were both about the same. I wish I would have spent more time running the evo4 to see how good it could have been....Maybe next time!
Dave You sent on diff gear for the extra diff...I made a spool out of it and the small screw that holds the pinion on to the end of the front drive shaft came off and wedged into the gears....So I had to bum one from Kilruff (thanks by the way Jimmy!!). Need to order some spares for next time!!
EA
EAMotorsports is offline
Old 08-16-2004, 05:09 PM
  #1098
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by KilRuf
Actually he stripped it out when he ran a diff up front. Some uhhh screw came loose and got caught up in the gears. He couldn't find anymore. So I gave him my spare since I was running the 415 instead.
OK I see...
JDM_DOHC_SiR is offline
Old 08-16-2004, 05:12 PM
  #1099
EA
Sweet.. glad that you like it.. BTW I have more spares coming your way along with the Blue caps
-Dave
PM me if you get a chance... have to talk something about the 22nd of Aug
  #1100
Originally posted by Hebiki
dave.. YGPM dude
Back to ya
Old 08-16-2004, 05:40 PM
  #1101
JimmyMac's Avatar
Hey Dave, Eric showed me the uhhh special bumper you had for him. How bout sending one my way!!
JimmyMac is offline
Old 08-16-2004, 06:03 PM
  #1102
JimmyMac's Avatar
Has anyone found an online blank setup sheet yet??
JimmyMac is offline
Old 08-16-2004, 06:10 PM
  #1103
Ahh You like that... .. I make them in my spare time at work with some of the lathes that I have here the material cost is quite high ... But PM me if you would want one
-Dave
Old 08-16-2004, 06:32 PM
  #1104
rice's Avatar
has anyone weighed his evo4 with esc,batt,rec,servo,tires and body?
rice is offline
Old 08-16-2004, 06:35 PM
  #1105
1490Grams on my EVO4 with full options ect ect... and quite a heavy body
go a few pages back to see what gear I have on mine
-Dave
Old 08-17-2004, 02:30 AM
  #1106
EVOtech's Avatar
1420, all up. Beat that!
EVOtech is offline
Old 08-17-2004, 04:04 AM
  #1107
FUK_WRX's Avatar
Look who's trying to get a tamiya
FUK_WRX is offline
Old 08-18-2004, 07:08 AM
  #1108
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
JDM_DOHC_SiR how do you like the EVO4 vs. you killer Cuda's you have? Our local shop is a pretty huge Tamiya dealer and was looking at possibly getting the new EVO4 or a 415. Not sure yet but just gathering up info at this time. The EVO4 looks very similiar the my Cuda R2 I has as far as the drive train and the open gear setup. I know the 415 is really nice car overall and wins at the top level and I expect the EVO4 is going to be no exception.
Brian
wyd is offline
Old 08-18-2004, 03:22 PM
  #1109
Brian
I like it quite a bit.. the car is still young and does have to weak points IMO..
#1 ... 950 bearings are really small....easy to send to that trash
#2 Center driveshaft cups...Very prone to breaking in a BIG CRASH. but there are a few aftermarket comanies that are working on a fix to this as we speak
other than that the car works really well out of the Box and is very forgiving with setups
-Dave
Old 08-18-2004, 08:17 PM
  #1110
hierog's Avatar
Default finally bought her
after much agonizing, I finally bought the evo IV!! And I was just getting used to my Evo III SE too! any good insight about putting her together before I break open the box? JDM, how can I get with you to get some spare parts? seems like your the man to help out with overseas parts!
thanks
vic
hierog is offline
