Tamiya TB-Evolution IV >
Old 08-02-2004, 03:27 AM
  #886
taisantobi's Avatar
i like the car very much so far,
its nearly as fast as my yokomo out of the box (with the included yellow springs). its only 1/10 second slower on our local indoor carpet track
i have to work a little on the play in the front one way (like dave posted). the building of the car is a breeze......
but be careful! don't hit anything, because after every hit the car has lots of tweak.
tobias
taisantobi is offline
Old 08-02-2004, 04:29 AM
  #887
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: tweak problem
Originally posted by taisantobi
hi,
i have a little tweak problem with the car, did someone have the same experience and how can i solve it?
thanks for your replies
Tobi
I have found that using 3 center posts helps a little and also check the bulkheads where the 2 screws for the center shaft holder go they can get knocked out od shap rather quick..screws bent ect ect,..
-Dave
JDM_DOHC_SiR is offline
Old 08-02-2004, 05:09 AM
  #888
taisantobi's Avatar
are the 3 center posts in the kit? i just have seen the big plastic part......
Old 08-02-2004, 10:57 AM
  #889
BigDogRacing's Avatar
taisantobi- looks good, but if your carpet track has ANY traction then yellows are WAY too light. blues, whites or white front blue rear is probably what you need and 50/40 shock oil with 3 hole pistons. Start with yellow front swaybar and red rear then go up from there after you find the right springs. You might also try raising the rear roll center to get more steering.
BigDogRacing is offline
Old 08-02-2004, 11:18 AM
  #890
racer's Avatar
you get two small centre posts with the kit as well.
racer is offline
Old 08-02-2004, 03:09 PM
  #891
Holmenkollen's Avatar
Does anyone know if flourine coated ball nuts and ball connectors are included?
Holmenkollen is offline
Old 08-02-2004, 03:19 PM
  #892
jeffreylin's Avatar
nope
jeffreylin is offline
Old 08-02-2004, 03:21 PM
  #893
Nope ...but the kit comes with nice "Heavy" steel ones
-Dave
Old 08-02-2004, 03:26 PM
  #894
Hebiki's Avatar
Trader Rating: 26 (100%+)
i have them on my TRF415.. they're niiiiiiiiiiiiiiiiiiiiiice
Hebiki is offline
Old 08-02-2004, 10:14 PM
  #895
SpeedTech's Avatar
Hi Guys,
Tamiya USA finally (finally!) received their shipment of EVO IV we should get them sometime this week and be ready to ship by the end of the week or early next week.
Steve Wang
SpeedTech is offline
Old 08-02-2004, 10:21 PM
  #896
eeyan's Avatar
Steve.... will the spare parts be available when the kits do get in?
eeyan is offline
Old 08-02-2004, 10:32 PM
  #897
FW-05RR's Avatar
what spares do you need?
FW-05RR is offline
Old 08-02-2004, 11:08 PM
  #898
F. Alonso's Avatar
There has been a thread that's opened up about free drivetrains with people claiming that when the motor isn't attached, that they can blow onto the spur gear and the drivetrain will move, with the wheels attached and everything in some cases.
What is it like for other Evo IV owners out there??? Dave?? Any ideas??
F. Alonso is offline
Old 08-02-2004, 11:27 PM
  #899
Neil Rabara's Avatar
Does Tamiya usually put out a TRF version after some time after a car's release?
Neil Rabara is offline
Old 08-02-2004, 11:30 PM
  #900
FW-05RR's Avatar
lets play a guessing game
How long before the TB Evo IV is outdated?
4 more months
FW-05RR is offline
