Old 12-14-2009, 03:42 AM   #3466
Toh WL's Avatar
Originally Posted by B18C Turbo View Post
good to hear man, sorex tires are very good in build quality and construction, very consistent and have great longetivity.
Way to go I am using Sorex tires too. How about the rims I m not sure anyone better than SpeedMind?
Toh WL is offline   Reply With Quote
Old 12-14-2009, 07:19 AM   #3467
phisher's Avatar
Trader Rating: 14 (100%+)
I'm stocking up on replacement parts for my Evo IV. A 90T spur gear seems hard to find. TamiyaUSA has some but I was wondering if anyone knew of other manufacturers spur gears that would work? Robinson Racing seems to have some that look close but I'm not sure they would work. Suggestions?
phisher is offline   Reply With Quote
Old 12-14-2009, 08:16 AM   #3468
SammyZ's Avatar
Trader Rating: 138 (100%+)
any spur gear will work, have you stripped any yet? how many packs do you have on the car?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 12-14-2009, 08:30 AM   #3469
phisher's Avatar
The kit came with two spur gears, a 90T and a 96T. I have not stripped any yet but tapped a wall and loosened the motor which caused a little wear on the gear. In a pinch I could swap the 90T (currently used) for the 96T and re-gear until I get a replacement.
Old 12-14-2009, 09:35 AM   #3470
Toh WL's Avatar
If you are to connect motor pinion & spurs. Just put a piece of plastic wrapper in between. That will prevent any knocks which wear both pinion & spur tooth. As for the motor in the mount. Just tighten it using 2 screw drivers connected as T. But don't strip the screw thread... else you have problems dismantling motor from the mount.
Once done just manually turn the spurs see if any blockage. Else you need to loosen the motor & readjust again.
Old 12-14-2009, 11:32 AM   #3471
phisher's Avatar
Yeah, I know about aligning the spur and pinion gear. I was just wondering what other brands of spur gears would work with is this. Thanks.
Old 12-14-2009, 12:10 PM   #3472
SammyZ's Avatar
i had that same problem with my Yokomo SD. I'd tap the wall and I guess the motor would loosen? causing the spur to strip slightly? I think you really need to be using a hex bolt and get some serious torque on those screws.
Hotbodies USA
SweepRacing USA
Old 12-15-2009, 09:38 AM   #3473
Toh WL's Avatar
Any brand of spurs will work eventually if u stick to 64 pitch. If you want to do mod just measures the spur & pinions to match up.
Old 12-15-2009, 07:48 PM   #3474
phisher's Avatar
I have read that having a "one way" front end makes it harder to achieve controlled braking. Especially in panic situations. Does anyone have any suggest about keeping this in check to make braking more controlled? When I'm heavy on the brake the back end slides out.
I would like to thank those of you in this thread that have taken the time to reply to my questions. You have all been a big help.
Old 12-15-2009, 08:57 PM   #3475
Toh WL's Avatar
The problem with one way is more noticable at modify 4.5T motor going through corners. The car swings up front making braking harder. Hence you turn in larger circle.
To solve this prob use the TB03 direct driver (spool). The car stops immediate upon braking.
Old 12-17-2009, 07:43 AM   #3476
phisher's Avatar
I just ordered a TB03D Direct Coupling from Tamiya's website. Anything I need to know before installing this seeing how it's really for a TB03?
Old 12-17-2009, 09:52 AM   #3477
SammyZ's Avatar
order some 10mm shims or whatever size it is i can't remember to shim the side-to-side play until you get the ring/pinion mesh perfect
Hotbodies USA
SweepRacing USA
Old 12-21-2009, 06:55 PM   #3478
phisher's Avatar
Anyone know if the Evo V gear covers with fit onto the Evo IV? They look the same but I'm not sure.
Old 12-21-2009, 07:49 PM   #3479
Toh WL's Avatar
The safest bet is to download the manual for evo IV & V then compare the part no.
If you shop for the part, the label would indicate compatible model u can use. You won't go wrong with that.
Old 12-22-2009, 04:22 AM   #3480
Blueman Austria's Avatar
No ! they are different!
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
