Old 11-27-2009, 08:51 AM   #3436
Toh WL's Avatar
Originally Posted by phisher View Post
When considering an Evolution IV, what spare parts might one also consider? I have a feeling my local hobby shop doesn't carry Evo parts and these would have to be ordered before race day. What parts should I keep on hand?
You may need to order...
1. propeller joint B
2. spur mount
3. center cup
They will get spoiled if your track has pebbles & small stones.
Toh WL is offline   Reply With Quote
Old 11-27-2009, 09:03 AM   #3437
SammyZ's Avatar
Trader Rating: 138 (100%+)
i'd like to add to that:
ball diff ring/pinion gears
one-way ring/pinion gears
Arms
C-hubs
Knuckles
Hingepins
Ballstuds (steel)
Titanium steering turnbuckles
Spur gears
Diff parts
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 11-27-2009, 09:07 AM   #3438
Toh WL's Avatar
Arms
C-hubs
Knuckles
Hingepins
Ballstuds (steel)
Spur gears
Diff parts
Well these are common parts I can get from LHS. As for the 3 items listed, my LHS has to make special order directly to Tamiya Japan. Eventually it took me 3 months in waiting.
Old 11-27-2009, 09:30 AM   #3439
SammyZ's Avatar
ahhh very nice, i see you live in setapak which could prove
to be more difficult in ordering parts through distributors.
Hotbodies USA
SweepRacing USA
Old 11-27-2009, 09:41 AM   #3440
Toh WL's Avatar
BTW I am sourcing from local tamiya agent Stargek..
Old 12-02-2009, 07:06 AM   #3441
phisher's Avatar
Trader Rating: 14 (100%+)
What pitch spur / pinion gears does the Evo IV have?
phisher is offline   Reply With Quote
Old 12-02-2009, 07:09 AM   #3442
Toh WL's Avatar
Both of them are of 64 pitch. Pinion provided is 34T & spurs 90/96T.
Old 12-02-2009, 07:14 AM   #3443
Toh WL's Avatar
Originally Posted by Evoracer View Post
In case you missed them, I have 2 Evo 4's for sale here on rctech. Parts are really not a problem as with any Tamiya most of the good deals are from Hong Kong or Japan shops. Ebay works wonders. These cars are rock tough. The Evo drivetrain became really good with the intro of the Evo 4. You'll actually learn that many Tamiya cars have similar parts. The Evo 4 shares some with the TRF415 and with the TA05.
In addition the TB Evo 5 makes good drifting machine. For touring it may not be forgiving in comparision with belt driven car like TRF415 & TA05. I had experience with torque steer. The workaround is just watch your fingers don't throttle too hard on the remote.
Old 12-02-2009, 07:19 AM   #3444
phisher's Avatar
Thanks Toh.
One more question. I will be running a 17.5 turn brushless Novak. The owners manual states I can safely have a final drive gear ratio of 4.5. That would mean I could use a 45T pinion with the 90T spur (final drive would be 4.59). That seams high to me. Is that correct?
Old 12-02-2009, 07:29 AM   #3445
Toh WL's Avatar
Thanks Toh.
My suggesting is you take the recommended gearing for a start. Just run around see if your ESC or motor does really heat up or not.
If you run 4.59 instead of 4.5 your car is slower more torque. Try reduce one pinion teeth at a time & observe the motor & ESC temperature.
Old 12-02-2009, 07:32 AM   #3446
phisher's Avatar
Old 12-02-2009, 07:37 AM   #3447
Toh WL's Avatar
My advice is always use the internal ratio provided on the car manual. For example TB Evo 5 int ratio is 2.437. Do you calculation you'll indeed get the correct and accurate gearing.
Old 12-02-2009, 07:55 AM   #3448
phisher's Avatar
The Evo IV has an internal gear ratio of 2.294. That would make a 45T pinion the correct gear to stay under the 4.5 final drive but its just seems like a big pinion gear. I have never run touring car, been an off roader most of my time in RC. I will pick up a few different sized pinions with 45T being the largest and work my way up. That is, unless someone see some huge flaws in my thinking?
Old 12-02-2009, 08:02 AM   #3449
Toh WL's Avatar
I guess you have to look at the track condition to set accordingly. If it's a small track with so many curves or corners. You surely need higher gearing. If it's a huge long track you can lower the gearing but do take note of the motor temperature as well ESC. The safest bet is to have cooling fan on both. A temp gun can be handy.
Old 12-02-2009, 12:04 PM   #3450
phisher's Avatar
Anyone know why the Evolution IV is not discontinued and all the other versions of the Evo line are (i.e. V, MS, III, etc...)? When shopping for an entry level, high quality touring car, I found myself on the Tamiya website where I noticed the Evo IV discounted to $230. I figured this was a good deal for a high quality car. But being curious has lead me to wonder about the other models in the Evo line, especially the new versions of the Evo, like the V. I have seen that the Evo IV is still winning national level races in the stock class. Is Tamiya just trying to liquidate the remaining stock of Evo's or are they still popular enough to sell?
My Evo gets here tomorrow, and as much as I want to open it up and put it together I am honestly scared that in a few months I will not be able to find parts.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
