Old 05-21-2009, 08:45 PM   #3406
SammyZ's Avatar
Trader Rating: 138 (100%+)
do you have any hi-res pics of your cars?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 05-21-2009, 09:20 PM   #3407
JimmyMac's Avatar
Mine is in pieces right now. Gonna toss on 416 suspension. Maybe I'll snap some pics once I'm done. Plus I have to fix my bent steering arm. They tend to bend if you don't run servosaver and crash really hard.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is online now   Reply With Quote
Old 05-21-2009, 09:40 PM   #3408
SammyZ's Avatar
im confused I know the trf416 uses the same arms that come standard on the Evo IV so im not sure what your changing?
Hotbodies USA
SweepRacing USA
Old 05-22-2009, 01:09 AM   #3409
JimmyMac's Avatar
Let me correct myself... I'm switching to 416 WE or Evo V arms. The short arm set. But the 416 did come with new hubs, caster blocks, and spindles with 10x5 bearings and not 9x5 bearings. Also with C/C front and XA/E rear blocks. I never ran long arms on my 416.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-22-2009, 09:19 AM   #3410
SammyZ's Avatar
oh nice man!
The evo IV/416 arms are 2mm longer than the Evo V/416WE short arms? Am i correct on that
Does the Evo V/416WE arms, hubs, & knuckles drop right onto the evo IV?
Hotbodies USA
SweepRacing USA
Old 05-22-2009, 09:58 AM   #3411
Trader Rating: 28 (100%+)
Hey guys,
A couple more questions
(1) have you guys run the evo 4 without the stabiliser bars? I prefer to keep things simple and am wondering what effect not-running the stablisers would have.
(2) I have fitted the optional pro (David Jun) rear end...does this offer any real advantage?
Thanks,
Steve
stephenianjames is offline   Reply With Quote
Old 05-22-2009, 06:57 PM   #3412
JimmyMac's Avatar
oh nice man!
No, Evo IV arms are 1mm longer than Evo V arms. Everything drops in, only problem is you also need to change out the axles. Evo IV axles do not fit the new hubs.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-22-2009, 06:59 PM   #3413
JimmyMac's Avatar
Originally Posted by stephenianjames View Post
Hey guys,
Thanks,
Steve
I normally run without swaybars. What is your track like? High traction? Big and fast?
I never ran the DJ suspension. I thought I heard is helps with low traction. Just be careful if you crash. I think they tweak easy.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-23-2009, 10:04 PM   #3414
Thanks Jimmy,
I ran the car for the first time today, practising at my local track. It was very quick for a 17.5t brushless, geared at around 3.65 FDR, but I found it wanted to oversteer when powering out of corners especially when turning right. Would this be an effect of torque steer?
I would have thought a 17.5t wouldn't be too bad with TS. A fellow racer has suggested lessening the front droop and increasing the rear(currently it is at 5mm front, 4mm rear) which he tells me will decrease power on steering. I'll give this a go and race at a club meeting this coming Wednesday night...the only chance before the state titles. I hope I can get it sorted in time!
Are there any other tips to making the thing more stable through the turns?
Cheers,
Steve
Old 05-23-2009, 10:15 PM   #3415
SammyZ's Avatar
if it cuts hard to the right? has it been on a tweak station?
Hotbodies USA
SweepRacing USA
Old 05-23-2009, 11:12 PM   #3416
JimmyMac's Avatar
Is the car balanced left to right? Less front droop should help take out some on power steering.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-23-2009, 11:55 PM   #3417
B18C, I don't have access to a tweak station unfortunately. The car has only just been built so I'm hoping it's not tweaked, although I guess you can tweak it when building to.
Jimmy mac...the car isn't balanced left to right as yet...it is right side heavy so I'm sure this does have a big effect on the handling also. The problem is the car is right on the legal racing minimum without any balast (1400gms with body, no transponder). I may well need 50 or 100gms on the battery side (currently running a IP3800 25C lipo) to get the balance right. Is it OK to put the ESC on the top deck...I would have thought this raises the COG too high...my receiver is tiny but my ESC rather large so this might be the answer...obviously the servo if fixed as is the motor.
Thanks guys again for such rapid responses...do you run your cars overweight to get the balance right. Could someone please post a pic of their electronic setup on this car?
Cheers,
Steve
Old 05-24-2009, 12:01 AM   #3418
SammyZ's Avatar
no i run my cars underweight because i am a cheater. Even if the car is new you woudl still need to tweak the car on a tweak balance tool of some kind.
The car usually does wierd and unpredictable things as you described unless you put it on this tweak device. I know there are several companies that make them. It looks like this.
Hotbodies USA
SweepRacing USA
Old 05-24-2009, 01:45 AM   #3419
Thanks B18C...is this the same as a setup station?
Excuse my ignorance but I thought tweak was the chassis (or another component) warped duw to impact or fatigue etc.
Old 05-24-2009, 07:16 AM   #3420
SammyZ's Avatar
your right, tweak can be caused by both of those problems. No this is different from a setup station. In my opinion a setup station is an expensive paperweight. The car will always be different when on the wheels/tires your running.
This tweak station will balance the car from left to right using spring preload collars. Its an excellent tool and should be mentioned in all instruction manuals.
Hotbodies USA
SweepRacing USA
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
