Old 05-09-2007, 12:04 PM   #3361
thecrow2k's Avatar
No, its actually to check it compared to my Evo III to see if I can use the evo iv shaft.
thecrow2k is offline   Reply With Quote
Old 05-09-2007, 01:05 PM   #3362
fraz's Avatar
Send a message via AIM to fraz
I recall this being discussed before and they are not compatible. Drive trains are different. Same with the bevel/spurs, etc.
fraz is offline   Reply With Quote
Old 05-09-2007, 01:26 PM   #3363
thecrow2k's Avatar
The Bevel gears are perfectly compatible. Thats why the Evo III boys run the Evo IV front one way gear.
As for the drivetrains. The bearings used in the gearboxes are just flipped. Te motor mount bearings in the Evo III are the gearbox ones in the Evo IV and vice versa. Its only the length that could be the problem. As for spur gears, they're universal.
Old 05-09-2007, 07:20 PM   #3364
waOscar's Avatar
I do not agree that the are the same. You maybe able to run IV gears in a III, however do not attempt that the other way around. The III for one didn't use a screw to hold in the bevel gear, like the IV does. Also the internal ratio of the IV is differant to the III, although if you swap both front and rear to IV then it will not matter.
The shafts on the two cars are totally differant. III uses a one piece shaft, IV uses a collection of bits and pieces.
Anyway to anwser your original question.
I can't not get an exact measurement for you without romoving the shock tower, but its around 3.5-4mm.
It you need a more accurate measure, it will have to wait untill the weekend when I get some time to work on the car.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 05-10-2007, 01:21 AM   #3365
peejay's Avatar
The ring gear (diff or one-way) is the same for all the Evos (and the TB02), 39T. The internal ratio is changed by the different sizes of bevel pinion: 15T in the III; 17T in the IV; and 16T in the 5.
To ease assembly, the Evo III prop shaft is actually too short, resulting in too much fore and aft play in the drive line and consequent problems with gear meshing. The 3-piece Evo IV shaft helps to correct this error.
peejay is offline   Reply With Quote
Old 05-10-2007, 12:00 PM   #3366
thecrow2k's Avatar
Yes Peejay I was intending to use the evo iv 3 piece shaft, your saying this works?
Old 05-10-2007, 06:51 PM   #3367
WC
WC's Avatar
Trader Rating: 28 (100%+)
just get the Tamiya HopUp "Lightweight Shaft" for your EvoIII,
its 2mm longer and cures most of your spur stripping issues.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 05-11-2007, 01:02 AM   #3368
peejay's Avatar
Tamiya
No, my bad, I didn't finish my sentence properly - it helped correct the problem for the Evo IV.
I doubt that the 3 piece shaft will fit the Evo III because of the different bearing arrangements. You could download the III and IV manuals from Tamiya to compare the 2 assemblies and the parts you would need, but WCs suggestion is a simpler solution, although still not perfect.
I am sure that there was much discussion about this in the Evo III thread on here.
Old 05-11-2007, 09:33 AM   #3369
thecrow2k's Avatar
I already have the lightweight shaft and have shimmed the gearbox to no avail.
The bearings are the same used in the evo iii just in a different order.
Old 05-12-2007, 04:24 PM   #3370
thecrow2k's Avatar
Can anyone pleaaaase do this, it only takes a minute.
Old 06-07-2007, 03:52 AM   #3371
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Is it still easy to get spare parts for the Evo 4?
Cheers
Drift_Buggy is offline   Reply With Quote
Old 06-07-2007, 04:53 AM   #3372
waOscar's Avatar
Cheers
no problems in Australia, where are you?
Old 06-07-2007, 05:16 AM   #3373
Im in Central QLD.
I was reading a review by XRC/RC411 and they weren't happy with slop in the rear hubs and the drivetrain requiring special attention for shimming. Has anyone had had major drama with these 2 things?
Cheers
Old 06-30-2007, 05:11 PM   #3374
got a link? I have no problems on mine.
Im in Central QLD.
Cheers
slomo is offline   Reply With Quote
Old 07-07-2007, 04:48 AM   #3375
This is for infokiz, i believe you still remember me.
I'm still waiting for the evo iv i bought you trought ebay.
I'm trying to contact you by ebay and by mail, but it's impossible, the dispute on ebay was closed without any notice.
i believe you could read this to get a reply.
Please, i want to know anything you know about the car, because it doesnt arrived yet.
Thank you.
oscarin2000f is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
