Tamiya TB-Evolution IV
#3346
Originally Posted by BlackKat
Anyone know where I can get a new lower chassis plate for my Evo IV?
I had to buy a complete car to get a new lower deck so, if you do find anywhere, please let me know and I'll order a couple of spares.
Good luck
#3347
Alright .... Tamiya USA is haveing an Evo IV Blowout sale .... 250 bucks delivered to your door step. I am racing an evo IV now, so if I buy another kit I will be married to that chassis for another year or two!! I will probably need all the spare parts I can get ..... Oh well, I am going for it!!!!
#3348
Hello. I would like to know if any one knows if the Tamiya spool for this kit will fit in the TB02. Thanks for your help.
Jujubean
Jujubean
#3349
Hi everybody.
I have just bought a tamiya evo IV MS, and i would like to know if i can put aluminium diff outdrives to my rear diff (wich?), and also what parts do i need to build a front diff for this car.
Thank you
Thank you
#3350
Jujubean
Jujubean
Yes it fits no problems just make sure you shim it for proper gear mesh
#3351
Originally Posted by oscarin2000f
Hi everybody.
Thank you
Thank you
The aluminim diff from the evo5 may work but you'll need diffrent diff rings. the ones from the TA04. I haven't tried it out yet. But I know my evo4 diff fit in my evo5. I would check this out for you but I sold my evo4.
Here are the parts you would need to build a front diff for the Evo4
50992 Diff Joint Set
51110 Ball Diff Ring Gear
53379 3mm Steel Diff Balls x10 or any other 3mm Diff Balls
9805670 Ball Thrust Bearing
9805671 Diff Spring
53030 850 Ball bearing x2
53563 Diff Plate
49350 Cap Screw & Lock Nut
Hope this helps.
Where did you buy your Evo4Ms from? I wonder if it was the one I just sold.
#3352
Hi everybody.
Thank you
Thank you
#3353
#3354
Thank you for your help. I believe it's this part too, but i'm not sure.
Will yokomo SD diff joints fit on EVO IV?
Thank you again.
Thank you again.
#3355
Hi infokiz.
I have bought it throught ebay, and it's for spain, don't know if it's yours EVO IV.
#3356
Yep that's my car you bought.
#3357
Would anyone be kind enough to measure some things on their Evo, no need to disassemble.
1) From where the input gear goes into each gearbox. E.g. the distance inside from the rear gearbox to the front
2) Distance from the rear gearbox to the start of the mtoor mount
Heres a diagram
Heres a diagram
#3358
Anybody!
#3359
I am selling my Evo IV. Its as new and has quite a few hop up parts. If interested send me a PM. I am based in the UK.
#3360
Originally Posted by thecrow2k
Would anyone be kind enough to measure some things...
