Old 02-20-2006, 12:03 PM   #3256
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Speedtech RC has tons of EVO-IV parts.
On another note...I have one I'm thinking of selling. It's pretty optioned out (just about everything you can get from Tamiya, DJ rear and all)...any suggestions where I should sell it? It seems like this place isn't too good to sell cars.
I'd like to get $300 out of it, if only as a static art piece...I've never raced it (got it used, fixed it up some and stopped racing onroad). I just like staring at it. Beautiful car.
Ebay? I've never sold anything there before (only bought stuff)...seems a little tricky to get it right...maybe another RC board out there?
Turbo Joe is offline   Reply With Quote
Old 02-20-2006, 02:40 PM   #3257
hierog's Avatar
speedtech usually has all that you need. Jason's Store off of ebay has a pretty good selection of stuff too. If all else fails, try Rainbow Ten. If they don't have it, the it's probably out of stock at tamiya too!!
vic
hierog is offline   Reply With Quote
Old 02-20-2006, 11:10 PM   #3258
jhigga15's Avatar
I just got some extra arm from Speedtec and the Much More Tire Warmers...Quick Shipping!!!
jhigga15 is offline   Reply With Quote
Old 02-21-2006, 10:50 AM   #3259
fraz's Avatar
Send a message via AIM to fraz
I agree, Speedtech is probably the best in the states.
I need a favor if any of you guys can help. I am breaking out my Evo4 for our new spec class but we are using stick pack batteries and I lost my plastic parts for the battery mount and strap. Anybody that runs side by side batteries have a set laying around they can kick down? Happy to pay shipping for some parts that I am guessing most of you don't use.
TIA
fraz is offline   Reply With Quote
Old 02-21-2006, 11:18 AM   #3260
ljohnson's Avatar
fraz, if you don't get the plastic parts for the stick pack mounting, you can tape stick packs in using the two tape slots in the middle of the chassis. It's not as clean as using the holder, but it works. The middle tape slots are also useful if you're using split side by side packs, like ones from a saddle pack car.
ljohnson is offline   Reply With Quote
Old 02-23-2006, 02:25 AM   #3261
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
i have a new ride (yes a evo iv)
bit slow in catching up with you lot
since there are not many setup sheets
droop (where to start )
oil`s on carpet rubber
is worth using the metal ring for one-way or go over to plastic
where can i get a carbon battery strap (taping is for loser`s )sean T
springs
are the all white ones (hard tuned) better then the muti coloured ones
got any poundage rates for these things
roll bars (sean T they work )
part no. for r/bar set
staying with normal 9x5 bearings coz even the yoke ones 10x5 pack up regulary aswell
do the X blocks of 415 fit on evo apart from being 1mm lower ,is this better ??
is the tamiya spool up to it (strong enough)
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 02-23-2006, 07:17 AM   #3262
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
Cool
Mr. Jolly,
As far as the springs are concerned, you can pick up the complete set of the Associated touring car springs and they work perfectly on the Tamiya shocks. Plus, there's a nice little piece of paper in there that gives you the rating of each spring. On our carpet track here in the states (CEFX Raceway) the Associated purples on the front and the coppers on the rear seem to be the hot ticket.
Tony
RcCzarOfOld is offline   Reply With Quote
Old 02-23-2006, 08:51 AM   #3263
jw
jw's Avatar
Mr Jolly & RcCzar,
Wow, heavy springs... what oil are you running RcCzar?
I am trying 50wt front and rear with Tamiya White springs on the front and Tamiya Yellow on the back.
But then I use battery tape (loser )
Also, I have an extra stock battery strap, the plastic one if you need it MrJolly.
I would be interested in more setup ideas. I am running on carpet with rubber tires (TakeOff27).
Thanks,
John
jw is offline   Reply With Quote
Old 02-23-2006, 11:35 AM   #3264
jw, I'm runnin 50wt front and 40wt rear. Runnin foam tires on carpet. Purples and Plaids. I also tape my batts. That entire battery strap assembly is just dead weight in an already heavy car.
Tony
Old 02-23-2006, 11:54 AM   #3265
PaZ
PaZ's Avatar
jolly ive got a battery strap think its plactic though if you want one sent up for free. Im startin with 40wt front 40wt rear blue springs front yellow rear, thats what i was advised by sean and its working so far. If you get your evo 4 going like it was at plymouth id need a copy of your set up
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 02-23-2006, 12:56 PM   #3266
Sean T Guy's Avatar
Jolly,
Ali diff ring is for 1 way only. Most important thing that I have found with my evo was to put rubber "O" rings under all top deck screws to avoid tweaking a very tweaky car.
2nd most important thing I have found is to check orange sponges in shocks. These go above the diaphrams and when they go flat with wear then they just dont work properly.
The spring chart I have is the one that the springs come on.
Red = soft
Yellow = medium
Blue = stiff
White = extra stiff
Roll bars Mmm , I tried them on my "MSX" this weekend and have to eventually agree that they work. I used 2 degs castor which wasnt the best idea so I have already put 4 on.
Your set-up wasnt far off at Plymouth Colin ---- Mine was
The battery strap I used to use was of the mission with a very slight file to one of the holes. I also used 2 ball cups with the cups cut off screwing upwards alongside the batteries to stop the batteries shifting out sideways.
Got to say that tape is easier and better in blue
Schumacher Racing UK
Team Scream UK
eXpress Motorsports UK
FTQ Models
Sean T Guy is offline   Reply With Quote
Old 02-23-2006, 01:01 PM   #3267
Sean T Guy's Avatar
Oh Yeh....
If you are getting a spool then get the xenon one with metal outdrives cos the plastic ones with break as soon as you look at a barrier.
Team Scream UK
FTQ Models
Old 02-23-2006, 04:17 PM   #3268
MR JOLLY's Avatar
just been racing 40wt front & rear but 2 hole pistons
wasen`t very nice atall going back to 3 hole 50wt blues springs all round 4 deg castor
got a plastic one it`s crap need a nice carbon one
sean you are right though it does twaek very easily
rzcar
we are on rubber on carpet so your spring`s will be way to hard setup for us
Old 02-23-2006, 04:37 PM   #3269
fraz's Avatar
I carefully countersunk the upper deck and the car doesn't hold a tweak like it used to.
Old 02-24-2006, 09:24 AM   #3270
Sean T Guy's Avatar
Since fitting the ally "T" between decks and using the rubber "O" rings then I havent had any tweak problems.
I use losi 40wt with 3 holes on my nearly new sorex 24's Colin.
Maybe instead of countersinking the carbon topdeck you could use the countersunk washers , I think they make them in tamiya blue aswell... SWEEEEEEEET.
Team Scream UK
FTQ Models
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
