Old 04-28-2005, 10:19 PM   #2926
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Originally posted by JDM_DOHC_SiR
so the bearing clearance is a little bit tighter?? in the the hub
-Dave
much tighter
Rod, Thanks for the info.
See you this Saturday with the new goodies!
madjack is offline   Reply With Quote
Old 04-29-2005, 09:03 PM   #2927
berger's Avatar
R/C Tech Charter Subscriber
Ran mine tonight for the first time, 27t stock on carpet with foam, just wanted to get a practice run in, im mainly doing asphalt racing this year, first impressions were very good, felt nice and smooth, transisted well etc. Managed to break it though Pulled the screw through the front knuckle at the bottom which i then lost and didnt have a spare for. Doh!
This used to be a common problem on the TC3 (for me anyway ) Is there a wider front bumper/stiff foam bumper i can use to help limit damage.
Also, the front and rear end seems to have quite a lot of slop in the hubs/wishbones, im guessing the alloy rear hubs fix that end, and some light shimming will be good for the front, not what i was expecting really though, thought Tamiya had perfect fit and finish.
What springs are people running, ive only got the tamiya yellows which ive no idea on the lb's of, my alex ones fitted but are a little bigger in inside diameter but are usable (i ran those instead) rayspeeds are too big and pop off the bottom.
berger is offline   Reply With Quote
Old 04-29-2005, 11:21 PM   #2928
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
Earlier on, i'd a problem on spur keep on stripping.
found out that the spur holder was too loose, i gotta add on shims (in between the motor holder and the spur holder).
thanks
Windtalkers is offline   Reply With Quote
Old 04-30-2005, 11:02 AM   #2929
fraz's Avatar
Send a message via AIM to fraz
I use a Trinity Reflex 200mm bumper. It is red and top plastic part only needed one hole cut in it and I trimmed down the front edge to fit in a 190mm body. Works great and protects the wheels well. I first did this when I started running a spool and the wheels are protected way better than before.
fraz is offline   Reply With Quote
Old 04-30-2005, 11:26 AM   #2930
berger's Avatar
Thanks, ill see if i can get one as i almost only run a spool now, just love how they handle
Old 05-01-2005, 12:59 AM   #2931
berger's Avatar
Just resealed my whole chassis sanding it properly. I did it quick in the week so i could run it but wasnt happy with the finish, the glue came off really easy in most places too so musnt have been very good. Sanded it all down with 600~800 grade paper and took those sharp edges off. Its come up very nicely now Just a cosmetic thing, little dribble that ran onto the surface, nail varnish remover or acetone should get rid of it using a Q-Tip to apply it?
Quick one, whats the biggest 48dp spur that fits, im guessing a 75-78? I ran a 69 last night which was my spare from my cuda and i had to have the motor mounted as far over as it would go with the pinion i was running..
Old 05-01-2005, 10:53 AM   #2932
Csaari77's Avatar
Trader Rating: 34 (100%+)
The only way to get a 78 tooth to fit is to sand a recess in the top deck. You just take off a little material from the edges around the spur and it will work out fine.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 05-01-2005, 06:13 PM   #2933
berger,
I had the same problem w/ my Evo's steering knuckle screws pulling out. I just replaced the 3 X 10 flat head screws w/ button head screws. The threaded portion is just slightly longer and gets a better grip in the knuckle. I haven't pulled one out since. Also, I'm using Associated springs on the car, they fit perfectly.
John Barta is offline   Reply With Quote
Old 05-01-2005, 08:43 PM   #2934
berger's Avatar
Thanks, ill see what screws ive got in my box, im sure ill have something suitable. (Hope im not breaking things often where i broke it is very hard on the cars, 90 degree right hander at full throttle, i took it too tight and hit a metal pillar supporting the whole mill building ) Ill probably just stick to using the alex springs, i do have an almost complete set of them....
Old 05-03-2005, 03:07 AM   #2935
Thai3g_Eclipse's Avatar
Hey guys,
Just picked up a Tamiya EVO IV roller, and I must say I am very impressed with the car in terms of quality and and design. I am having a few problems finding some parts for the car though -- particularly the batter holder and strap. Does anyone know where to get it? I looked at SpeedTech R/C and they are out of stock. Also, since this is my first Tamiya, what are things to look out or replace on this car to enhance it or prevent any problems further down the road? Help is greatly appreciated, thanks.
HPI Savage Flux HP | Tamiya TB-03
Thai3g_Eclipse is offline   Reply With Quote
Old 05-03-2005, 09:05 AM   #2936
Csaari77's Avatar
Don't bother with the battery strap. Just tape the batteries in and call it good. The strap lets the batteries pop right out of the chassis.
Old 05-05-2005, 05:58 AM   #2937
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Talking EVO4 MS Back from the Orange factory
A couple more things and she back to more testing
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-05-2005, 05:59 AM   #2938
Default Re: EVO4 MS Back from the Orange factory
-Dave
Old 05-05-2005, 06:00 AM   #2939
Default Re: Re: EVO4 MS Back from the Orange factory
Old 05-05-2005, 06:01 AM   #2940
Default Re: Re: Re: EVO4 MS Back from the Orange factory
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
