Tamiya TB-Evolution IV
#2824
Originally posted by Csaari77
Is the Evo IV MS out in the states yet? I've got one pre-ordered and I going crazy waiting for it. Are the new trans cases going to help with the tweaking problems of the original car?
Originally posted by JDM_DOHC_SiR
Building it up as wee speak... the new bulk heads are the sHiZ' ... pic"s to follow with a track report buy the end of the weekend
-Dave
-Dave
#2825
Someone suggested on this thread that in order to fit 28 mm foams in the front, a perfect replacement would be the R/C Square aluminum castor block. Does anyone know what needs to be replaced in the rear if I were to put 30mm foams? Or would they just fit easily?
#2826
MS Shakedown
Well after about 12 packs through the Evo4 MS and quite a few taps on the boards... I can finally say that this car is a Bit quicker with the set up that comes out the box..and it is less prone to chassis tweak with the new bulkheads .....THe new bulkheads also do not pinch the bearings like the Older Bulkheads... One other small change that I noticed is that the Battery slots are ever so slightly spaced further apart... (GP3700/IB3800 cells)... but it might just be me but they fit better in the chassis than they do with the normal EVO4 chassis ..even though they have the same part #..?? ..
anyways this car will get more batteries through it next weekend... more to come
-Dave
-Dave
#2828
Hey guys, need some advice. I have an Evo 4 that I can't sell, so I've decided to just build it. What are the essential hop-ups for it (Besides the aluminum rear hubs, I have those already). Looking at speedtech.com, looks like there's 1-piece lightened front and rear input shafts, the MS bulkheads/gearcases, and the aluminum one-way gear. Anything else?
#2829
I'd also get the aluminum drive cups as the plastic ones will split in a crash. And also the lightened main shaft.
#2832
Originally posted by RC Driver Gary
Those are the one-piece input shafts, aren't they? or are they something different?
#2834
All you need is the sway bar set and a bunch of the toe blocks...and if you can bribe someone for the clear/smoked/transparent blue gear cases...then you would be all set.
My Evo4 is proving to be an amazing rubber tire on carpet car. No real runs on asphalt yet.
