Old 02-26-2005, 09:25 AM   #2746
Trader Rating: 62 (100%+)
Alonso, how did the 78t spur fit, did you have to shave the top deck?
patrick is offline   Reply With Quote
Old 02-26-2005, 01:54 PM   #2747
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Just got the stuff on Friday and haven't looked at it for my Evo IV yet. Will let you know though.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 02-27-2005, 05:51 AM   #2748
Ballsie's Avatar
Originally posted by MDL
anyone have the EVO 4 MS part number?
MDL
49353 - due to be released worldwide in March.
Ballsie is offline   Reply With Quote
Old 02-27-2005, 07:26 AM   #2749
I tried the 78 but the spur was a little outside of the buttom of the chassis. 77 is just nice. U do need to chamfer the upper deck a little else it will scrape the upper deck.
Chhers
viper1 is offline   Reply With Quote
Old 02-27-2005, 08:28 AM   #2750
F. Alonso's Avatar
Yeh, still yet to try it out as I've just been flat out. I may be moving away from the Evo IV fraternity though but I won't be a traitor like Hebiki!!! I will probably get a 415MS because for Modified its a much better chassis then the Evo IV. The Evo IV seems to be too stiff and doesn't quite have the consistentcy that the 415MS is. Also helps when you can get one for a good price.
Simon Feigl
Old 02-27-2005, 10:08 AM   #2751
Send a message via AIM to GroffBall
I bought my EVOIV from WYD and some of the suspension mounts have a 1 on them like 1A, 1B, etc... What does this mean?
GroffBall is offline   Reply With Quote
Old 02-27-2005, 12:03 PM   #2752
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
Today at the local race, I had my worst nitemare. Any1 ever encountered these problems b4??
1) Stripped spur gears (I stripped 4 new ones)
2) Stripped bevel gear (3 pcs, front ones. amazing the big one still intact)
3) The rear keep swinging (no problem using spool but problem occurred using one way. What's the droop setting should be used?)
Thanks for the help.
Appreciate it.
Windtalkers is offline   Reply With Quote
Old 02-27-2005, 02:35 PM   #2753
dawgmeat's Avatar
Default 28mm foam on front LW suspension solution!!!!!!!!!!!!! follow-up
with the dogbones I incountered a problem with the top king pin. When fully tighten doen it will rub agaisnt the the drive axle to fix this just remove a slight portion of the threads.
here is example
dawgmeat is online now   Reply With Quote
Old 02-27-2005, 02:35 PM   #2754
dawgmeat's Avatar
Default Re: 28mm foam on front LW suspension solution!!!!!!!!!!!!! follow-up
here is example
LW on the left and stock on the right
Old 02-27-2005, 02:38 PM   #2755
dawgmeat's Avatar
Default Re: Re: 28mm foam on front LW suspension solution!!!!!!!!!!!!! follow-up
this is what it look like with Jaco 28mm rim, note these tires have been run yet so there is just a little bit of foam material overlapping the rim
Old 02-27-2005, 02:40 PM   #2756
dawgmeat's Avatar
Default Re: Re: Re: 28mm foam on front LW suspension solution!!!!!!!!!!!!! follow-up
using the A/C blocks put dead on 190mm, if you need to go narrower, use the world kit blocks
Old 02-27-2005, 02:58 PM   #2757
dawgmeat's Avatar
Default Re: Re: Re: Re: 28mm foam on front LW suspension solution!!!!!!!!!!!!! follow-up
ball cups rubbin' against the rim will not be a problem
I'm sorry for those people who didn't see my earlier post, you will need to buy the Sqaure STB-35B steering arms, the kit come hardware do not DISCARD you will need them. installed the flange tube on the bottom half of the castor from the top, place shim on top of flange tube and there you go LW suspension ridin' on foams
the only people who have this item is champ: http://www.rc-champ.co.jp/ good luck
Old 02-28-2005, 09:41 AM   #2758
groffball-that means they are 415 blocks, which will sit the arms lower on the chassis. I have them on my evo4, works good.
Old 02-28-2005, 10:58 AM   #2759
Send a message via AIM to loosenut
Default Diff. shim adjustment question
Got a question...
On the instruction (step 3) it says to put (3) 10x.03mm shims on the left side of the rear diff. and (1) 10x.1mm shim on the right side...but with this - there's still alot of play! IS it ok to put an extra 10x.03mm shim on the left side of the diff.? I did that and the play was almost gone but I noticed that the diff unit is not as center ... as least as much as I like it to be...
Thx.
Gary
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 02-28-2005, 12:27 PM   #2760
Hebiki's Avatar
Trader Rating: 26 (100%+)
i guess the new MR4TC BD is NOT helping either huh?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
