Old 02-17-2005, 03:16 AM   #2701
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Oh right. I think you can post info here with info like that.
Thanks!
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 02-17-2005, 03:18 AM   #2702
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by Hebiki
am i still allowed to post here?
F. alonso.. i used a 70T and a 72T 48P spur on my former evo. i think you go all the way up to 76T before you start hitting the chassis. i remember that was the limit for my former barracuda R3
What are you doing up at this hour? Can's sleep with all the guilt from defecting to Yokomo?
jeffreylin is offline   Reply With Quote
Old 02-17-2005, 03:21 AM   #2703
Hebiki's Avatar
Trader Rating: 26 (100%+)
just need to build the shocks..and it'll be done! and im a night person. dont you know that yet?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-17-2005, 03:45 AM   #2704
F. Alonso's Avatar
I'm happy, someone from the US to talk to at my night time. Its 9:45PM here on the 17th. Have fun with the shocks ............ traitor!!!
Simon Feigl
Old 02-17-2005, 04:02 AM   #2705
TRF415boy's Avatar
Originally posted by hierog
It all depends on the track!! Where I run (Speedworld, in CA) we run monster stocks around 6.9 to 7. Epic binarys run well around 7.25 to 7.35.
If I were to gear any lower, the motor would melt!!
Beat ya, here we run the Monster Stock at 8.2 - 8.5 if the track is a bit twisty. I'll take a pic of the track somewhen (not this week, but next week) if you guys want to know where we have to run these crazy ratios.
PS : yes it's really twisty and laptimes are between 14 - 16s depending on the week and tightness of the track.
TRF415boy is offline   Reply With Quote
Old 02-17-2005, 09:07 AM   #2706
Trader Rating: 62 (100%+)
I run a 77 tooth spur on mine, any smaller and the pinion wont reach if your running low turns. I run 7 turn with a 18 to 20 tooth pinions.
patrick is offline   Reply With Quote
Old 02-17-2005, 09:25 AM   #2707
F. Alonso's Avatar
So you gear between 8.83 and 9.81?? Just want to make sure I got my gearing chart all good for 48dp.
Also... do you have any more clearance between the top deck and and the spur gear?? What's the biggest Spur you've tried?? I just wanna get the biggest spur that I can fit in there and stick with that, just buy lots of different pinions.
Simon Feigl
Old 02-17-2005, 09:44 AM   #2708
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
Originally posted by F. Alonso
I really have a love affair with Tamiya. I think that they are great chassis with no holes barred to get the most precise construction and quality of components. I will run Tamiya as long as I can withstand the pressures of joining a team through an importer. I just wish that something could be done within Australia to get the numbers up in the top level of the game. There are some great Tamiya Runners here, such as the current Tamiya F1 World Champion, Bradd Vercoe. I just am dismayed by the lack of support. Hopefully someone will come to the rescue soon to bring Tamiya to the top of the Australia Racing Scene. I'm gonna do my best but its hard when you have to pay retail for everything :P
I think it's quite the same everywhere as the support is entirely up to the distributor/importer...
However, I think things might be different over here as the fight for market share (between two different brands among 2 distributor) has began intensely.... well the previous dist got to another brand while the new one takes over the twin star brand... heck... it's kinda complicated.
anyway, the love for the stars are immense among local racers and we're holding it tight... it's all among the racers... some will defect and some will stay...
godspeed....
Windtalkers is offline   Reply With Quote
Old 02-17-2005, 09:46 AM   #2709
has any1 tried the new suspension mounts (XA, XB, XC & XD)?
how are they compared to the normal ones?
Old 02-17-2005, 09:49 AM   #2710
F. Alonso's Avatar
From what I understand from the 415 blocks, these are just narrower then the X block. So XA is another .5 deg narrower and so on until XD. I've heard some people have been very impressed with the cars once you get them a bit more narrow, so I think it'd work well. I'd like to try something like XB at the back of the front, with B at the front. So its narrow, as well as having the swooped arm effect.
Simon Feigl
Old 02-17-2005, 02:46 PM   #2711
for tftr your gear ratio should be between 7.9 to 8.5 for an 8 depends how u set up the motor and timing
also for a 9 would be closer to 7.8 to 8.3
this is with v2s and 5mm arm
syntex1 is offline   Reply With Quote
Old 02-17-2005, 05:12 PM   #2712
F. Alonso's Avatar
Oh okay, thanks for that. I was using 8.3 on the weekend and I wanted to go lower. It was a BAAAAAD weekend unfortunately. For some reason my car just didn't want to handle at the top end of the track, but was pretty good at the bottom of the track. WEIRD!
Simon Feigl
Old 02-17-2005, 06:20 PM   #2713
try running stiffer rear oil 40front 45rear 0r 50rear should help also try running some anti dive in the front
Old 02-17-2005, 07:15 PM   #2714
The problem is not the spur hitting the top deck, but hitting the ground. I tried an 81 tooth spur, but it stuck out past the bottom of the chassis! I think 78 or 79 would be the largest you would want to use.
Old 02-17-2005, 11:50 PM   #2715
fraz's Avatar
Send a message via AIM to fraz
Pics from the Nuremburg Toy Fair:
http://www.radiocontrol.gr/galleries...erg2005273.htm
http://www.radiocontrol.gr/galleries...erg2005274.htm
http://www.radiocontrol.gr/galleries...erg2005278.htm
Here's the saucy new tb-02r that looks impressive.
http://www.radiocontrol.gr/galleries...erg2005277.htm
fraz is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
