Tamiya TB-Evolution IV >
Old 02-14-2005, 03:12 PM
  #2641
Originally posted by loosenut
Can someone give me tips on how to CA glue the chasis? I tried using Super Glue (thick gel) - cyanoacrylate BUT I couldn't get it to be very smooth and also after it dried it had those annoying white marks from the fumes....am I suppose to use a special kind of glue? Also should I prepare the shock and upper deck edges as well?
Gary
Or you could put the chassis in a vice and run a bead of super glue around the edges
Chazz
Chazz is offline
Old 02-14-2005, 05:07 PM
  #2642
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by Chazz
Wow, your selling your IV , how come
Chazz
Chazz
absolutely LOVE the car... but im selling it because i get bored with cars. i wanna build something (i love building things for some reason) and then test it.. race it.. vicious cycle. (good for hobby shops though).
if no one bites.. ill keep it and race it still.. although i want to try something very RADICAL and DIFFERENT.
Hebiki is offline
Old 02-14-2005, 05:25 PM
  #2643
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default tb evo 3 diff
hi all first post in this section.
can any one tell me if you can get an aluminium rear diff drives for the tamiya tb evo 3 surikarn...
i keep destroying the delrin diff ..i run 8 x1 with foams..
i keep the diff tight and well maintained but the diff plates keep getting hot and melting the delrin..its an exspensive part and im a bit peed off.
mike
mikecatts is offline
Old 02-14-2005, 06:06 PM
  #2644
Default Evo IV carpet setup
Devon Racer,
Here is the setup that I've been using for stock racing on carpet w/ good results the last few weeks:
Front End
use diff instead of oneway
shocks-60 wt. fluid, Associated purple springs, pos. #3 on both arm and tower
camber link-stock position
wheelbase-stock position
susp. blocks-A/A
swaybar-blue
-2 deg. camber, 4 deg. caster, 0 deg. toe
may try -1.5 deg. camber if car oversteers on corner entry
ackerman-stock position
Rear End
shocks-50wt. fluid, Associated red springs, pos. #4 on tower and #3 on arm
susp. blocks-A/C
swaybar-none
-2 deg. camber
tires-Parma plaid on front, purple on rear trued to 2.35" (need to use 6mm hex hubs w/ 1mm spacer on front to clear these tires)
droop-4mm front and rear (less if smaller tires are used)
ride height-5mm
body-Parma Alfa Romeo
Hope this helps....
John Barta is offline
Old 02-14-2005, 06:10 PM
  #2645
ngo8's Avatar
Default Re: tb evo 3 diff
mike
you should CA the diff plates to the out drives it should solve youre problems one thing put on lots of grease on the thrust bearing .
ngo8 is offline
Old 02-14-2005, 07:55 PM
  #2646
Windtalkers's Avatar
mike
and also keep the diff nut replaced from time to time....
Windtalkers is offline
Old 02-14-2005, 08:36 PM
  #2647
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Hebiki
If no one bites.. ill keep it and race it still.. although i want to try something very RADICAL and DIFFERENT.
??hmmm what would that be
-Dave
JDM_DOHC_SiR is offline
Old 02-14-2005, 08:38 PM
  #2648
Hebiki's Avatar
-Dave
wanna take a wild guess dave?
Hebiki is offline
Old 02-14-2005, 08:42 PM
  #2649
Is it something you have owned before.??
Old 02-14-2005, 08:43 PM
  #2650
Hebiki's Avatar
nope...
Hebiki is offline
Old 02-14-2005, 08:44 PM
  #2651
nope...
Is it Purple ??
Old 02-14-2005, 08:45 PM
  #2652
Hebiki's Avatar
Is it Purple ??
ill PM you when i get it. should be pretty soon. payday is tomorrow
Hebiki is offline
Old 02-14-2005, 08:48 PM
  #2653
T1FK05??
  #2654
OK
Old 02-14-2005, 08:50 PM
  #2655
Hebiki's Avatar
Originally posted by Windtalkers
T1FK05??
this "car" was at the worlds. thats all i can say.
Hebiki is offline
