Old 01-12-2005, 04:09 PM   #2431
PIIHB!'s Avatar
Does anybody have any carpet setups for stockw/ Foams?
PIIHB! is offline   Reply With Quote
Old 01-12-2005, 04:49 PM   #2432
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I might have one for you on Saturday. I will need to make a copy of it. Have not tried it yet though.
ST Racing Concepts (STRC)
Old 01-12-2005, 04:52 PM   #2433
PIIHB!'s Avatar
Cool. All those parts I ordered from Japan came today. I'll have a nice light car for saturday
Old 01-12-2005, 04:57 PM   #2434
wyd
Tech Legend
wyd's Avatar
Damn that was fast. My stuff still did not show!!!!!!!! I know Dave sent it and it shoud show any day now!!!!!!!! You will have a cool car now. I need to go over mine but I still didn't do it yet.
Old 01-12-2005, 05:05 PM   #2435
PIIHB!'s Avatar
Yeah! I also ordered all my spare parts through a hobby shop in Illinois. They had pretty much everything I needed in stock. Arms, joints, uprights, steering blocks, all the diff parts minus the screw 850 bearings and diff balls. I still need to pick up flourine ball ends. Jeez this is getting expensive........
Old 01-12-2005, 05:37 PM   #2436
JimmyMac's Avatar
I had a carpet foam setup but I forgot where I put it.... Actually I don't think I wrote it down since I'm using my 415 for carpet now hehe... But I believe I used 6mm wheel hexes for 28mm tire clearance for the front... AE Purple or Yellows springs for front and AE Copper rear springs. 70wt/f 50wt/r. 3hole pistons. Shocks on tower was outter most in rear and one in on front. Shock on arm was middle hole (3hole) front and inner hole (2hole) rear. Yellow swaybar up front. Short wheelbase for more rotation. 4degree caster blocks. 415 suspension blocks flat on chassis with C/A front and A/A rear. Camber link shims I think I had 2mm front and .5mm rear. Mazda6 body. 96spur. I don't recall my droop. Maybe 5 and 5. Front diff tighter than rear. Uhhh, I can't remember anything else. But it would be a start I guess.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-12-2005, 06:39 PM   #2437
wyd
Tech Legend
wyd's Avatar
Oh well you can't take it with you so spend that cash. Imagine how much money you would spend if you bought a leather jacket for Cans!!!!!!!!!!!
Old 01-12-2005, 06:52 PM   #2438
PIIHB!'s Avatar
How many cows had to die to make that thing!?!?!?!?!
Old 01-13-2005, 04:00 PM   #2439
He Brainteased
Wheres the pics? Did you sort it?
Galifrey is offline   Reply With Quote
Old 01-13-2005, 05:02 PM   #2440
PIIHB!'s Avatar
I'm having trouble fitting foams on the car AND maintaining a 190mm width. I got the 30mm rears to fit by moving the shock mount to the innermost hole on the three hole side of the arm and I used a red 1mm spacer. the prob is I can't get the front tires (28mm) to fit without spacing them out and exceeding the 190mm width. I was thinking of cutting the front tires down to a 26mm width and the rears to a 28mm width (so i could use the middle hole on the arm). Anybody else have problems like this w/ foams?
Old 01-13-2005, 05:10 PM   #2441
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Well I just tried to fit Foams to my car, only 26mm Ellegis and they seemed to go on okay with 6mm wheel hexes and a blue spacer, but a red spacer works better. I seem to have misplaced my calipers at the moment so I can see if I'm illegal or not.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 01-13-2005, 05:14 PM   #2442
PIIHB!'s Avatar
I think I'll go ahead and get my tire guy (WYD!) to cut them to a narrower width (maybe 26mm all around). I don't have the power/talent to make the wide tires have an advantage
Old 01-13-2005, 08:25 PM   #2443
wyd
Tech Legend
wyd's Avatar
Why do you have 30mm tires on the rear for. Use the middle hole on the 3 setup side and use 28mm with no spacer other than the 6mm spacer.
Old 01-13-2005, 08:59 PM   #2444
BrainTeased's Avatar
Originally posted by Galifrey
He Brainteased
i've got pics when i first fnished building the kit if your interested :P
but apart from that i havent changed the factory setup of the steering rod link (from servo to steering arm post) as i have changed holes on the front uprights ackerman to the inside holes and found alot more steering so i can now turn down my steering dual rate to 90 and have enough steering for left hand turns
and i still have to more tuning options to give me even more steering "C" rear toe in block needs to be fitted and 4 degree caster front C hub needs to be fitted (i've got the 2 Deg on ATM)
if you want pics ill have to email them to ya, i got it zipped up about 10 files
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-13-2005, 09:02 PM   #2445
F. Alonso's Avatar
Well this is my initial setup that I'm going to test
Equal Shocks F/R (Kit Oil, 40 wt I believe, 2 Hole Pistons)
Sway Bar: Red
Inclined Shock Angle two spots on Rear, 1 spot on Front
Springs: Tamiya White on Rear, Tamiya Grey on Front
Camber: Starting with 2 degrees Camber front and Rear and will see what wear is like.
Castor: 4 Degree Aluminium
Ride Height, 6mm F/R
Foams: 42F Ellegi Front and 40R UFRA Rear
We'll see how we go. If my settings seem a bit weird, let me know. I'm kinda pissing in the dark at the moment until I actually get to the track. I should be running on an untreated surface too against only Rubber boys so we'll see how we go.
Simon Feigl
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
