Tamiya TB-Evolution IV >
Old 12-27-2004, 12:30 AM
  #2236
Duh, just read the post above. Any more advice? What compound tires, etc...
Racinrc14 is offline
Old 12-27-2004, 01:42 AM
  #2237
fraz's Avatar
Depends on bite. A good baseline is orange/purple fronts with purple rears. Many I know run orange/double pink fronts with double pink rears. I tried the orange/purple fronts with double pink rears and I really liked that a lot. My current favorite is Trinity cyan fronts and magenta rears.
I posted some keys to my carpet setup earlier as you found and the car was on rails. I will try to get my current setup sheet in electronic form soon so I can mail it. Probably after the vacation break.
fraz is offline
Old 12-27-2004, 02:43 AM
  #2238
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by Randy Caster
Hey Chris, do you have a backup Evo IV that I could try out for a night? I'd like to try one before I buy a couple more MS kits for the year and have it be the wrong car for me.
Randy, cant you help there bro. i only have one evoIV (for now... ) and its set up primarily for stock. MAYBE for 19T. when/if i pick up another evoIV, you can drive it.
Hebiki is offline
Old 12-27-2004, 08:19 AM
  #2239
Leester's Avatar
Trader Rating: 22 (96%+)
Default diff in evo 4
Hey guys a quick question to ask you. Can you fit a diff in a evo 4 or can you not? thanks!
Leester is offline
Old 12-27-2004, 08:50 AM
  #2240
Default Re: diff in evo 4
Well it has one in the rear, so assume you mean the front...
In which case the answer is yes... the front and rear diffs are the same for this purpose
Galifrey is offline
Old 12-27-2004, 11:05 AM
  #2241
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I thought you only had the one, but figured I'd ask. I made a bunch of changes to the 415 yet again, hopefully they will give me the steering Im searching for.
Randy Caster is offline
Old 12-27-2004, 05:17 PM
  #2242
Thought I would clarify my above post..
The gearboxes front and read on the EvoIV are identical..
Therefore a rear diff will fit in a front gearbox and vice versa...
Galifrey is offline
Old 12-27-2004, 06:55 PM
  #2243
PIIHB!'s Avatar
Trader Rating: 14 (100%+)
I just sold my TC4 and bought one of these cars. What parts will I need to build a front diff? any necessary hop-ups needed? What normally breaks on the car? Thanks
PIIHB! is offline
Old 12-27-2004, 07:01 PM
  #2244
hierog's Avatar
upgrade the drive cups to aluminum ones, first off. and if you're gonna do that, might as well move to the lightweigh pieces. i haven't broken anything "regularly" with the exception of the original drivecups. i always carry spare arms and now front hub carriers.
Oh yeah, buy some 950 bearings too
welcome to the club!!
vic
hierog is offline
Old 12-27-2004, 07:06 PM
  #2245
fraz's Avatar
Yep, the diffs are the same front and rear. I have a diff, oneway and spool options for my car.
It is a little pricey to build a diff, but you will need:
diff halves
diff rings (same as f201)
diff balls
thrust bearing
diff spring
long 2mm diff screws
2mm diff nuts
parts tree with diff t-nut
two bearings from inside of diff
outdrive protector rings
It sure would be nice if all manufacturers started packaging complete diff kits. I remeber having to do this for my nitro sedan and it cost me $70 to build a set of backup diffs with different oils in them!!!
fraz is offline
Old 12-27-2004, 07:13 PM
  #2246
PIIHB!'s Avatar
Thanks. Who makes a spool for the car? Where can I get it?
PIIHB! is offline
Old 12-27-2004, 07:17 PM
  #2247
DerekEngland's Avatar
That will work, they are the same.
DerekEngland is offline
Old 12-27-2004, 07:49 PM
  #2248
F. Alonso's Avatar
Speedtech make one, looks quite good. I should have mine in the New Year.
F. Alonso is offline
Old 12-27-2004, 07:52 PM
  #2249
PIIHB!'s Avatar
I just ran across that on their site. I'll be ordering one when steve gets the new site done.
PIIHB! is offline
  #2250
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I have the standard stuff. A Arms and caster blocks. I would order the rear alum. toe in hubs. I need to call RCO tommorrow and place an order for a few parts. When I race with you I will have alot of the stuff you need.
wyd is offline
