Old 12-17-2004, 09:00 PM   #2146
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally posted by tamiyadriver
i will try to remember to get some pix... its kinda small, and tight lanes. makes your lines and passing areas much more important! lotsa fun, tho... might make a better driver outta me yet!
Thanks. Sounds like fun. It will also help your driving if you are use to driving on a really tight track.
ST Racing Concepts (STRC)
Old 12-18-2004, 02:43 AM   #2147
EVOtech's Avatar
Originally posted by Hebiki
weird... team orion says 0 deg? maybe there are two sets that got released?
http://www.teamorion.com/global/global_news.asp?id=2676
Tamiya are 1 degree and Square are 1.5.
EVOtech is offline   Reply With Quote
Old 12-18-2004, 03:23 AM   #2148
Hebiki's Avatar
Trader Rating: 26 (100%+)
i guess the world replica kit is the only one that comes with 0 deg. hubs
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-18-2004, 05:41 AM   #2149
TRF_SPAIN's Avatar
Yes it is, only the new replica comes with 0 rear hubs
1 hubs -> TRF414 (TA04 first releases also)
2.5 Hubs ->TRF414M, TBEVO3, TA04R
1 New ones -> TBEVO4, TRF415MS
0 -> TRF415MS Worlds kit
TOP RACING & SY BRAND
TECHNICAL RACING PRODUCTS
Xtremehobby
D-Drivesports
TRF_SPAIN is offline   Reply With Quote
Old 12-18-2004, 08:48 AM   #2150
V12
V12's Avatar
I think TRF414M, TBEVO3, TA04R rear hubs are 2
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 12-18-2004, 10:49 PM   #2151
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
any people running a spool in there EVO yet?
I would like to know where you settled on shock oil weights...40 & below?
madjack is offline   Reply With Quote
Old 12-18-2004, 10:52 PM   #2152
wyd
Tech Legend
wyd's Avatar
I run a spool in my EVO. I think after tonight I will go a little stiffer front shock out as the car is a little twitchy. It had great highspeed steering. Need a little more rear traction and need to slow down the over all reaction of the car. I run foams on asphalt and have been running the 3 hole piston with 40wt. Think I need like 50 or 60 in the front.
Old 12-19-2004, 05:26 AM   #2153
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I want to get a spool for the Evo IV. I have seen the speedtech spool and am wanting to get that, but not happy about the photo id ordering for international orders. Is there any other spool made up for the Evo IV??
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 12-19-2004, 06:14 AM   #2154
wyd
Tech Legend
wyd's Avatar
Not that I know of. I actually have a diff but I made it into a spool. My diff has absolutely no slip. A normal spool is stronger but but a standard diff made into a spool is alot lighter.
Old 12-19-2004, 06:25 AM   #2155
F. Alonso's Avatar
How did you get it so tight??? I have a spare reinforced Diff that I could put together. What did you do to it to get it to not slip?? The screws don't seem to be long enough to screw it in REALLY tight because the locking piece of plastic that the flange nut goes into, it quite flimsy.
Simon Feigl
Old 12-19-2004, 06:50 AM   #2156
wyd
Tech Legend
wyd's Avatar
You can do it one of two ways. You can remove the diff balls and then use thin sandpaper like the way Losi does it and then tighten the diff down tightly. It won't be slipping at all.
Now mine is actually the white diff half from the EVO III and that uses a alum diff nut instead of a plastic one so you can crank it down a little tighter. I have mine built just like normal but tightend enough that when you check it it is super tight. I know with my setup I can have the pinion on the motor and turn the front tires and it will spin the motor and have no diff action.
Old 12-19-2004, 07:00 AM   #2157
F. Alonso's Avatar
Okay, I'll have to try that out. Thanks for the help. I have the Evo III diff cups so I'll try the second method and see how we go. If no good, then I'll try the first method. Worst comes to worst, Araldite works a treat. Just a shame if I want to change the ring gears. (I did do this on my F201 ages ago and it was quite good).
Simon Feigl
Old 12-19-2004, 07:03 AM   #2158
wyd
Tech Legend
wyd's Avatar
Using a spool with increase your risk of damaging your fears in a big wreck, especially when hitting the walls and still being on the throttle. Alot of stress on the gears. I have not had this problem but have on other shft cars in the past when running spools, (PRo4 and Cuda) both ate gears when I had a spool.
Old 12-19-2004, 07:08 AM   #2159
F. Alonso's Avatar
Yeh, the car tends to do that as it is anyway, so that's not TOO big a deal. At the moment I've just been running ball diff at rear (quite loose) and oneway at front.
Simon Feigl
Old 12-19-2004, 09:57 AM   #2160
hierog's Avatar
yes, there is!!! Jurgen makes great products and is very quick with his responses! Well worth the $$
vic
http://www.swebs.dk/jurgen-diffs.html
hierog is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
