Old 03-19-2010, 09:48 PM   #1
*BBB*'s Avatar
Default How important is a foam tire truer?
I just ordered 24 ofna foam tires and they come trued. I race on a parking lot surfce maybe 3-4 times a week.. I dont want to waste my investment and want to keep the traction
So would one of these really be worth the $150? Or is it only importnt if you compete at a pro level?
WORK HARD PLAY A LOT HARDER!
[ Inferno VE MM2650 ][ Inferno GT2e MM2200 ][ XO-1 ][ Baja 5B ][ Baja 5Te ][ Jato ][ Grave Digger ][ MERV ]
*BBB* is offline   Reply With Quote
Old 03-19-2010, 09:51 PM   #2
pakk's Avatar
Trader Rating: 79 (100%+)
well if you chunk a lot like I do, you can turn a useless chunked tire into a good tire.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 03-20-2010, 04:07 AM   #3
Depends on the track, the track I drive 1/12th at, anything over 44mm at the rear chunks in 2 runs even if you dont hit anything...
So getting 2 runs out a non trued tire or 10 runs out of a tire that has been trued to 44mm is worth the investment...
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 03-20-2010, 06:56 PM   #4
A tire truer is a worthy investement.Buy a good one and it will last. I've had my Max-Mod for 20 years. It was expensive when I bought but I still have it and it works fine. What do you do when your once trued tires are all different diameters after running. Simply re-true them and save your investment.See what truers some of the guys at the track are using and ask them what they think.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 03-20-2010, 07:43 PM   #5
*BBB*'s Avatar
Alot of tires come trued now though.. like the ofna foams i am getting....
Old 03-20-2010, 07:51 PM   #6
Regional Moderator
CarbonJoe's Avatar
Sure, they may start out that way, but after running, they may not wear evenly. A truer allows you to "square" them up (remove coning, for example). A truer will also allow you to round the edges.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
R/C Car Tuning Lesson 1: Tires artwork Colorado Racing 14 11-21-2014 08:43 AM
Foam vs Rubber.... MartynD Electric On-Road 38 01-14-2005 12:16 AM
R/C Tech Live @ the 2004 Novak US Touring Car Championship futureal Electric On-Road 362 01-23-2004 09:19 AM
