Old 12-17-2004, 11:47 AM   #361
Trader Rating: 37 (100%+)
ben.
thanks...i actually like the Excel style pieces better then the hpi ones.
if you made a version like that i would be interested....please post the drawings you mentioned....i'm sure if pricing was on par if not better then the Excel pieces they would sell.
one problem with the Excel pieces is that they are hard to get in the U.S.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is online now   Reply With Quote
Old 12-17-2004, 11:49 AM   #362
rc-zombies's Avatar
The excel parts are very easy to get... $20 for 4 pieces is very cheap...
I would rather see PRP comeout with aluminum bulkheads for the Pro4 with built in camber link mounts
Old 12-17-2004, 11:53 AM   #363
TeamPRP's Avatar
Default Original PRP camber brace design
I originally drew this along with the chassis kit back in Feb/March.
This would be a 2mm brace you would mount on top of the current camber mounts. You would need to drill holes in the camber mounts if you wanted to run the additional holes. This has not been tested, so I am not sure how well the camber mounts would hold up to addtional holes being drilled.
What do you guys think?
- B
TeamPRP is offline   Reply With Quote
Old 12-17-2004, 11:55 AM   #364
TeamPRP's Avatar
RC Zombies
I would really like to do that, but I am scared that HPI would release the same thing a month after mine came out, then I would be screwed!?!
Old 12-17-2004, 12:25 PM   #365
rc-zombies's Avatar
Originally posted by TeamPRP
RC Zombies
Erik said HPI has no plans of releasing aluminum bulkheads... but you never know....
probably best not to come out with them.
I like your camber link mounts... but I think drilling 2 more holes on the original bulkhead may weeken that area.
Old 12-17-2004, 04:19 PM   #366
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Ben that looks nice man.....cant wait to get one and see how they work.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-18-2004, 01:27 AM   #367
Skill's Avatar
I'd love to see some aluminium bulkheads for the Pro 4 Possibly integrating a design where you can get easy diff access, like what was posted on the Pro 4 thread a couple of months ago.
I tried adjusting the centre post position for the first time on my car last night, I've always run it in the middle hole, but I tried the front hole and somehow it managed to give me more steering and a bit more back end grip! Chassis is still going strong, 3mm is the way to go with foams on carpet!!
Skill is offline   Reply With Quote
Old 12-29-2004, 01:54 PM   #368
TeamPRP's Avatar
Thanks, skill. Great to hear the chassis is still working well for you!!!!
Kevin, I am getting a single prototype done of the camber brace. I might be able to send it to you for testing at the Novak race. There's a catch though, the proto is 2.5mm fiberglass, instead of 2mm graphite which it would actually be machined from if I decide to make some of these. The fiberglass proto is just to test fit and function right now. I'll shoot you an email...
Thanks!
B
Old 12-29-2004, 03:12 PM   #369
Kevin K's Avatar
Ben....Thats not a big deal let me know the details in an email.
Old 01-15-2005, 07:06 PM   #370
Default setups
can someone post their current carpet setup so i can get an idea of how to start with this chassis? if the best setup is one of the ones that has already been posted just point me to the right one. also the screw heads stick out slightly from the bottom of the chassis is there a good way to make the holes big enough so that the screws are flush?
mtflunky is offline   Reply With Quote
Old 01-16-2005, 02:06 AM   #371
Skill's Avatar
Hi,
I'm running 37 shore HPI 26mm foams all round on the car, with the HPI 25mm linear red springs on the front and yellow springs on the rear. The shocks at the front are on the inside hole at the bottom, and the outside hole at the top. The rear shocks are in the middle hole at the bottom and the middle hole at the top. I'm running a gold sway bar up front, and no sway bar at the rear. The centre post is in the most forward position and I am running the side plates. Pretty much everything else is as stock settings.
The main thing you want to do though is to run slightly harder springs than you were doing before, because I found that the car rolled a lot with the standard springs.
Old 01-17-2005, 10:35 PM   #372
prp....or kev :P
what do you guys think of 2mm lowers for rubber tire racing. seems most pro setups for the pro4 show them using 2mm lowers...
anyway...what is the chance of prp making some type of pro4 lower?
the team prp hts still looks awesome on carpet/foams...kev what turn mod were you running on sunday......your cars looked sick fast at AJs Raceway.
Old 01-24-2005, 01:27 PM   #373
TeamPRP's Avatar
Hey Nexus,
I have no current plans for a 2mm Pro 4 chassis. I do think a thinner chassis for the outdoor season would be nice but nothing is set right now.
Thanks!
B
Old 01-24-2005, 02:27 PM   #374
Send a message via Yahoo to Doug Gaut
mtflunky, I had good luck with Eli Ezrow's setup that is posted on the Pro4 thread with these changes.
Went with 10wt lower shock oil front and rear, Parma Cyan and Magenta tires, Parma Alfa, laid the front shocks in one hole and ran the rear arms 2mm farther back than stock. It would be a great setup for stock but 19t the car is on edge.
Doug Gaut is offline   Reply With Quote
Old 01-25-2005, 10:12 PM   #375
eli's has his car setup without a sway bar in the front. did you do the same? ive just never seen anybody not run the bar in the front
Mugen MRX-4R or X components Zac Project R/C Items: For Sale/Trade 4 07-19-2008 11:08 AM
TC5 w/ ITF components bgolat R/C Items: Wanted to Buy 1 05-17-2008 01:45 PM
Factory Team TC5 w/ITF components Kraig R/C Items: For Sale/Trade 1 04-21-2008 05:34 AM
Advanced Racing Components... Jay Dub Team and Company Discussions 2 03-30-2006 09:57 PM
