Old 03-18-2010, 05:22 PM   #1
mjw
mjw's Avatar
Default Attention: Jeff Cuffs
Hi Jeff, I have a few questions for you. 1/12 scale 13.5 - need a Tekin speedo setup and rollout for a small 60x60 track. Can you post your Phi '09 setup from Snowbirds or your latest rubber setup for 13.5 and 17.5 as well as speedo settings?
Thanks,
Mark Frechette
mjw is offline   Reply With Quote
Old 03-18-2010, 07:41 PM   #2
Lee_123's Avatar
Mike
Try the Horsham thread for Jeff.
http://www.rctech.net/forum/racing-f...009-a-249.html
Member of "The Seldom Seen R/C Racing Team"
RC10L (Pro 10, WGT), TC4, BMI DB12RR, Scalpel
Lee_123 is offline   Reply With Quote
Old 03-18-2010, 09:32 PM   #3
Thanks,
Mark Frechette
60x60 hmm throtle profile 5 2400 to 7000 rpm ramp 2.0 ramp rate 40 boost prob a low turbo 5 to 10 due to short track..1 delay 42pinion 76 spur start there. Should be a safe setting Check motor temp after 4 minutes.
Corally setup
What arms you running
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 03-19-2010, 07:43 PM   #4
mjw
mjw's Avatar
Thanks Jeff, for the quick reply. I do have the new arms, what's the best working setup you run now.
Thanks again,
Mark Frechette
Old 03-21-2010, 09:13 PM   #5
Thanks again,
Mark Frechette
4 degree caster, long links up on tower, second hole in on tower for shock mount, 40 wt oil 22lb tamiya pistons front and rear, 2mm spacers under outer link on rear upright, 3mm spacers on steering rack, this is all on jaco blues
Old 03-21-2010, 10:06 PM   #6
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hi Jeff
Can you give me the general setting for 4 cell batteries power with 17.5.RS Pro
I beleive the track is 60X80...Thanks
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 03-21-2010, 10:28 PM   #7
Originally Posted by Goingfast View Post
Hi Jeff
HMMM i havent run 4 cell in a 12th scale with brushless with the new software. This is just a starting point i would start at but remember the key is keeping an eye on temp so u dont cook a motor in practice. Throttle profile 5 neutral width 10, boost 40 turbo 10 .2 delay 2400 to 10000 rpm range. 2.0 ramp rate. start with a 76spur and a 44 pinion. Let me know how you make out
Old 03-21-2010, 10:43 PM   #8
Goingfast's Avatar
Well I remeber from year ...I had to gear down about 9 teeths smaller from 1S lipo to 4 cell... but with the 203 not sure..Thanks
Old 03-23-2010, 11:26 AM   #9
mjw
mjw's Avatar
Jeff,
Arms - front and rear, are they spaced forward, middle, or back? Are you running the double lower shock tower in the rear and do you run a solid axle or one-way. Could you also give me a speedo setup for 13.5/17.5 rubber.
Thanks again,
Mark Frechette
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-21-2015 12:54 AM
Horsham Rc Carpet racing 2009 Jeff Cuffs Racing Forum 3890 09-12-2010 02:01 PM
Warpspeed Demon and Demon 2 futureal Electric On-Road 2557 03-08-2005 03:41 PM
