Old 10-22-2010, 08:26 PM   #121
tallyrc's Avatar
Originally Posted by 20 SMOKE View Post
here is a update,i have the new front end and its 90% done i ran out of time before going to work but shouold be done tonight and will post a pic
I thought it was illegal in wgt? Or are you just testing?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 10-22-2010, 08:33 PM   #122
That depends on which WGT rules you use. If you use the ones that were created originally independent of any sanctioning body then yes the front end is illegal. However ROAR's WGT rules do not specify a sliding king pin and my guess is a lot of club level WGT classes will not have a problem with it either. I have a feeling the original WGT rules will eventually change to accommodate the new technologies.
Old 10-22-2010, 09:01 PM   #123
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
are you going to protest that i am using it
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-22-2010, 09:09 PM   #124
20 SMOKE's Avatar
Thumbs up
BMI Racing "Copperhead 10" Support and Discussion-rc-pics-008.jpg   BMI Racing "Copperhead 10" Support and Discussion-rc-pics-009.jpg
Jamie W
Old 10-22-2010, 10:05 PM   #125
dzstr's Avatar
Trader Rating: 20 (100%+)
Do the longer of the two sets of standoffs hold the battery plate or the rear chassis brace?
I will protest only if you win
dzstr is offline   Reply With Quote
Old 10-23-2010, 06:41 AM   #126
tallyrc's Avatar
depends if you beat me or not... kidding.. finally got all my stuff together so its a go for this weekend.. look me up at the race. i'll be with everyone else from village..
Old 10-24-2010, 06:07 PM   #127
20 SMOKE's Avatar
the new front end was flawless,i had rear traction issues the tires took 3 min to come in.after loctiting the grub screws which i should have.the track i ran on today was a tire eater i had left fr wear to do the long sweeper at the start and end of the straight which is expected i swapped the fronts around and fixing the grub screws i never ad more left front wear they both wore equal started with a 214 and ended with a 208 most went through 2 sets of fronts
Jamie W
Old 10-24-2010, 06:22 PM   #128
dzstr's Avatar
Old 10-24-2010, 06:43 PM   #129
20 SMOKE's Avatar
there are two stand offs that hold the brace down on top of the battery
Jamie W
Old 10-24-2010, 07:33 PM   #130
dzstr's Avatar
There are two sets of standoffs. One set for the battery plate and one set for the carbon chasis brace. The manual calls each set "long" but there are two different lengths. It appears the shorter of the two sets go on the carbon brace. Is that right?
Also, are the ball cups that go on the damper tubes the same size as the CH12 ball cups?
Old 10-24-2010, 07:41 PM   #131
20 SMOKE's Avatar
yes on the cups,the shorts are the rears
Jamie W
Old 10-24-2010, 07:47 PM   #132
dzstr's Avatar
Thanks!
Old 10-25-2010, 08:08 PM   #133
dzstr's Avatar
What are you guys using for a front bumper? Foam's from Jason are still a week or two away.
Old 10-27-2010, 10:51 AM   #134
InspGadgt for ROAR President! This is exactly the way things should work!
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 10-27-2010, 12:28 PM   #135
protc3's Avatar
I spoke with Bruce Corbone from SpeedMerchant who wrote the rules and he is going to be modifying the rules to make our front end legal for WGT. There will no longer be a sliding kingpin only rule.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
