Old 06-02-2011, 08:00 PM   #271
K Raceway Kissimmee Region 4 Event next weekend. Last time I ran there my car was very loose.
Dave Willits
dds6695 is offline   Reply With Quote
Old 06-02-2011, 08:33 PM   #272
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
see what jeff posts and i will see you at the region
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-03-2011, 07:38 AM   #273
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
ok sorry for the delay. When i got home from work yesterday i had some family over and completely forgot to post the set-up sorry guys. but here you go.
w/spec tires
front:
camber: -.5 deg
droop: 1mm
ride hieght: 5.5mm
toe: 0
castor: middle
1.8mm flex plates stiff position
shurlube #4 in front dampner tube
2mm spacer between the axles and the knuckles to widen the front end
servo laid down with tall ball studs on knuckles
center:
ride hieght: 5.5mm
used the silva shock from the copperhead 12
white spring crc.
35wt ae oil
stock shock position
stock flex plates in long position
2,000 wt oil in dampner tubes
battery down the center with esc and reciever towards the front of the pack. Idea was to have the wieght towards the front to calm down the car during wieght transfer in a corner. probably going back to mounting the battery across with elec. behind the pack.
rear:
ride hieght: 5.5mm
pod droop: 2mm for the bumps
zero pod sag
max track width
hope this helps.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 06-03-2011, 07:44 AM   #274
20 SMOKE's Avatar
what is the lbs of the wh spring,,thats close to mine but i use the stock shock and have a softer tc spring.
Jamie W
Old 06-03-2011, 08:02 AM   #275
10lbs
Old 06-03-2011, 09:53 AM   #276
Thanks for the reply. I will try to match as close as possible. I'm sure your esc settings were set for the conditions ??? I'll probably put the battery in the standard transverse location.
Dave Willits
Old 06-03-2011, 09:59 AM   #277
Sorry, but what are the 1.8mm flex plates ?
Dave Willits
Old 06-03-2011, 10:51 AM   #278
they are the front flex plates for the bmi front end!
Old 06-03-2011, 10:52 AM   #279
my esc is all linear with a non boost profile and im running a 10.5t
Old 06-03-2011, 02:10 PM   #280
tallyrc's Avatar
whats pod sag?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 06-03-2011, 03:31 PM   #281
Jeff,
Are you running the kit front end ? Thanks for the info. It will help a great deal.
Dave Willits
Old 06-03-2011, 03:40 PM   #282
20 SMOKE's Avatar
Originally Posted by dds6695 View Post
Jeff,
jeff has the new front end
Jamie W
Old 06-03-2011, 04:58 PM   #283
Dave Willits
Old 06-03-2011, 05:46 PM   #284
Originally Posted by tallyrc View Post
whats pod sag?
its where when the car is at ride hieght the front of the rear pod sits lower than therear of the pod.
Old 06-03-2011, 05:54 PM   #285
20 SMOKE's Avatar
It like anti squat or pro squat in tc lingo
Jamie W
