Old 10-27-2010, 12:50 PM   #136
Uga
Uga's Avatar
Originally Posted by protc3 View Post
I spoke with Bruce Corbone from SpeedMerchant who wrote the rules and he is going to be modifying the rules to make our front end legal for WGT. There will no longer be a sliding kingpin only rule.
Any info on when this is going to happen? This season already?
P.S.: Jason, did you receive my PM 2 days ago?
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 10-27-2010, 12:52 PM   #137
protc3's Avatar
I will need to find out when it will be in effect. I will keep you posted.
As for the 2S chassis, if there are enough of them in demand to warrant making a short run i can do it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-27-2010, 04:40 PM   #138
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
that is awesome,BMI changing pan cars for the future
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-27-2010, 07:03 PM   #139
tallyrc's Avatar
what was the price of that front end?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 10-27-2010, 08:30 PM   #140
20 SMOKE's Avatar
Jamie W
Old 11-01-2010, 07:59 AM   #141
protc3's Avatar
Copperhead 10 bumpers are here. I will put them on the website today. The price is $9.99
BMI Racing "Copperhead 10" Support and Discussion-cid_3d454f5f-3f35-41b3-8ce9-dc220bb81b92.jpg
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-01-2010, 08:33 AM   #142
20 SMOKE's Avatar
whats your carpet setup
Jamie W
Old 11-01-2010, 08:39 AM   #143
protc3's Avatar
Front:
Stock flex plates in soft postion
#6 shurlube on the tube
4mm ride height
6 degrees caster
1mm shim under hinge pin block
1.5 degrees camber
2mm shim behind front axles
.75mm droop
0 toe
Spec tire cut to 2.08
Rear:
Stock center spring and middle hole on shock mount/battery plate
45 wt. oil in shock
Stock flex plates mounted long
4mm ride height
1mm pod droop
#4 shurlube in the tubes
Pod level
Electronics behind battery and battery across the chassis
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-01-2010, 08:40 AM   #144
2wdrive's Avatar
Looks nice but how is it mounted on the chassis? is there a strap of some sort to hold down the foam bumper? otherwise the bodypost get the full brunt of the impact (even with foam bumper) and the foam can shoot upwards. Hitting a hard wooden beam full on with the weight of roughly 1130+ grams behind it is hard lol. (i know, you should not hit it in the first place)
2wdrive is offline   Reply With Quote
Old 11-01-2010, 09:05 AM   #145
20 SMOKE's Avatar
thats 98% what i have
Jamie W
Old 11-01-2010, 09:23 AM   #146
protc3's Avatar
It is actually the identicle shape of the carbon fiber bumper that lays beneath it. The foam bumper protrudes 1mm all around the lower C/F bumper. It is supported extremely well.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-01-2010, 01:51 PM   #147
sportpak's Avatar
Trader Rating: 26 (100%+)
When will the NFE kit for the 10 be on the website?
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 11-01-2010, 11:03 PM   #148
c-lyon's Avatar
Will it fit the DB10R? Thanks.
c-lyon is offline   Reply With Quote
Old 11-02-2010, 06:22 AM   #149
20 SMOKE's Avatar
yes cause jason used the same fr ends on all his cars
Jamie W
Old 11-02-2010, 08:07 AM   #150
c-lyon's Avatar
Thanks, I just wanted to make sure.
