Old 03-15-2010, 11:06 AM   #1
Numburn's Avatar
Default Balance
How important is L/R balance? I'm running a TC5. All my lead weights are on the lipo brace and I'm 14g over the legal weight. The car is still a little heavy on the motor side but is close to balanced. I want to add a motor fan/heatsink and take away a lead weight or two, but that would put me pretty far unbalanced. Is it worth it?
-Kevin McCoy
Tekno RC | Pro-Line Racing | Castle Creations | 92zero Designs
Numburn is offline   Reply With Quote
Old 03-15-2010, 11:16 AM   #2
rcterp's Avatar
Trader Rating: 35 (100%+)
Being balanced is definitely worth it, else your car will act differently on left and right turns. Being balanced is worth being a couple grams overweight if that what it takes on your car.
As far as where your weight is; if by Lipo brace you mean the battery bar that holds the lipo down I would suggest you move the weight off of that and onto the chassis, also put it further away from the center. This will bring your center of gravity lower and being further out from center will help balance that side.
For the TC5 I recommend the PPD Billet Lipo plate to help out.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 03-15-2010, 11:50 AM   #3
Numburn's Avatar
No, actually on the aftermarker brace that keeps the pack from sliding out. It's on the outside of the pack so basically as far from center as I can get the weights. I guess I'll just leave it without a motor fan/heatsink for now.
-Kevin McCoy
Old 03-15-2010, 12:31 PM   #4
I too am curious as to how much this affects the L/R balance of the car. I drive a corally PHI with the angled lipo tray. Does tweaking the car go hand in hand with balancing it left and right? or what order shoudl this be done in?
Last summer was my first summer of racing and while i didnt do amazing, i had plenty of 2nd /3rd place finishes (as well as DNFs). My driving is good, now its just the car holding me back, and my mind of not changing the setup. I have been adapting to the car and not adapting the car to my driving style. What order should my car be changed? (IE. tweak before you change XYZ, save ride height last etc)
Double D Donuts is offline   Reply With Quote
Old 03-15-2010, 12:34 PM   #5
rcterp's Avatar
Last summer was my first summer of racing and while i didnt do amazing, i had plenty of 2nd /3rd place finishes (as well as DNFs). My driving is good, now its just the car holding me back, and my mind of not changing the setup. I have been adapting to the car and not adapting the car to my driving style. What order should i car be changed? (IE. tweak before you change XYZ, save ride height last etc)
L/R balance should be done first, because as you move weight around the car tweak changes. The idea is to get your balance right and your suspension right so that the tweak is 0 (I just fought this battle with my car last weekend).
Φ
Old 03-16-2010, 08:31 PM   #6
anybody else have input on this? Still curious as to what people think.
Old 03-16-2010, 09:01 PM   #7
Potoczak's Avatar
Trader Rating: 112 (100%+)
I would say balance is the most important, then you work on your downstops, droop, ride height, etc.....
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
iMAX QUATTRO B6 Balance Charger/Discharger arrived with new super-value combo rcmart rcMart.com Mega Online R/C Marketplace 40 08-25-2012 08:56 AM
best lipo balance charger mike williams Electric On-Road 21 07-08-2009 06:37 PM
IRS Balance Tools for TC and 1/12th protc3 Electric On-Road 49 11-17-2007 07:52 AM
To Balance or Not to Balance Lipo Packs while charging RED-LINE M03 Electric Off-Road 25 09-04-2007 02:22 PM
Crankshaft Balance dameetz Onroad Nitro Engine Zone 59 03-16-2005 05:30 AM
