Old 03-14-2010, 06:55 PM   #1
MCSEDanny's Avatar
Default I'm that guy. Same old 1/12 questions.
Sorry I know the answers to all my questions are in the 25,167 posts below so I will accept say 3 flames.
I just got a 12RC5.1 and moved my Tekin RS Pro over and would like to find out if there is anything I need to add because of running only one cell Lipo. I have seen and heard about power boosters but not sure I understand what they are or what there for.
The car came with a KO Propo PDS-951 stearing servo. Is this a 6v servo? I run a Futaba 4PK and know i have to turn a feature off if it's not able to handle the 6v.
MCSEDanny is offline   Reply With Quote
Old 03-14-2010, 07:03 PM   #2
You will need to run a reciever pack because 1 cell doen't have enough voltage for the steering servo. I would get the Losy 180mah 7.2v 2 cell receiver pack.
KO servo's are good for at least 7.2v. That is what I use also...
Steve Dunn
Indianapolis
sdunnmcp is offline   Reply With Quote
Old 03-14-2010, 07:49 PM   #3
Damnit Man's Avatar
Send a message via MSN to Damnit Man
I'd recommend the team Epic 220Mah Life. That way it is closer to the 6V you need for the servo and has more capacity.
Donovan P.
Damnit Man is offline   Reply With Quote
Old 03-14-2010, 08:10 PM   #4
theisgroup's Avatar
straight from the top
Originally Posted by TeamTekin View Post
Yes putting a reciver battery in line with the switch looks pretty good. A little dangerous to let people start doing mods like this, but it is pretty straight forward and should be more robust than a booster or regulator.
You really only need to use another 1S lipo in the switch line. Now we are getting down to little micro helicopter batteries.
With this modification the voltage cutoff WILL NOT WORK.
Good options for 1S setups with the RS.
LiFe 6.6v receiver pack
4 cell, 5 cell or 6 cell Nimh or NiCd
1s or 2s lipo in line with the switch.
2s lipo with a 6v regulator
Booster connected to the main 1S lipo
Using a Diode to drop the voltage of a 2S is not bad, but a little more complicated to wire if you want full voltage to the servo.
Tekin Prez
actually ko is good on 2s so all the way up to 8.4v I think Robert at one point told me 9v, but don't quote me
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-14-2010, 08:17 PM   #5
chris moore's Avatar
Trader Rating: 88 (99%+)
Unless your going to run mod you can run a TQ booster(not a novak booster) even with the latest v203 with no problems. To run a booster or receiver pack is mostly a personal thing as thay both do the same function, I dont want another batt to charge between runs so I use the booster with my 13.5 1c setup.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 03-15-2010, 03:46 PM   #6
tim fry's Avatar
How are you wiring your booster in with the Tekin as I need to do mine?
tim fry is offline   Reply With Quote
Old 03-15-2010, 03:51 PM   #7
oeoeo327's Avatar
Trader Rating: 74 (100%+)
There's only one connection that's required to power the booster - it's a red wire that needs to be soldered to the (+) post of the ESC. Plug the 3 wire connector into the battery port of the receiver, and you're done.
Pretty simple, huh???
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 03-15-2010, 03:54 PM   #8
tim fry's Avatar
Thats how I had have it on my LRP but I heard something about putting it inline with the switch so it sees a higher voltage???
Old 03-15-2010, 05:02 PM   #9
PDX-Spike's Avatar
Note - When you wire the booster that way, you do not use the ESC on/off switch. Instead, use the booster switch.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 03-15-2010, 05:48 PM   #10
Steve Dunn
Indianapolis
However Tekin said not to use 2cell LiPo reciever packs with the RS without a regulator as the higher voltage can damage the RS. So make sure to use a regulator. Or if you have a charger capable of charging LiFE cells then get the 6v 2 cell LiFE reciever pack so you don't have to worry about it.
http://www.rctech.net/forum/electric...packs-bad.html
Old 03-15-2010, 05:49 PM   #11
With the RS you turn on both the booster and the RS. If you do not then the LiPo cut off is disabled.
Old 03-15-2010, 05:56 PM   #12
bfong13's Avatar
Trader Rating: 17 (100%+)
Default 6.6v Life Rx Pack is the way to go for 1/12th
Just run a Life 6.6v receiver pack and call it a day. I just got one of these http://www.amainhobbies.com/product_...ack-66V-200mAh and ran it the other day. It was great! Charges alot quicker than the 7.4v Lipo receiver packs and you don't have to mess with the mess of a Novak booster. Tekin does not recommend using 7.4v lipos and and people have said that they have had problems using Tekins with boosters.
bfong13 is offline   Reply With Quote
Old 03-15-2010, 05:57 PM   #13
bfong13's Avatar
Steve Dunn
Indianapolis
No, Tekin does not recommend using a 2 cell lipo receiver pack. Use the 6.6v Life instead.
Old 03-15-2010, 06:59 PM   #14
hotdognobun's Avatar
Trader Rating: 31 (100%+)
HeyMCSEDanny! Here is the yokomo brace and spring retainer that we were talking about. Don't bother with the yokomo motor mount
I'm that guy.  Same old 1/12 questions.-dscn0633.jpg   I'm that guy.  Same old 1/12 questions.-dscn0714.jpg   I'm that guy.  Same old 1/12 questions.-dscn0739.jpg   I'm that guy.  Same old 1/12 questions.-dscn0741.jpg
hotdognobun is offline   Reply With Quote
Old 03-15-2010, 07:20 PM   #15
oeoeo327's Avatar
+1 - I use both switches... It saved my battery once. You can run the car w/o enabling the LiPo cutoff, but I prefer not to take any chances.
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 02:42 PM
The New Malta Guys Race Chat 10malta Malta R/C Racers 679 11-15-2004 09:19 PM
Tricities 2003/04 jjmudd Canadian R/C Scene 476 04-01-2004 08:52 PM
