BMI Racing "Copperhead 12" discussion and support
#286
DB1020R is a longer lower pod plate designed for the DB12RR. When put on the DB12R it would lengthen the wheelbase but the DB12RR has a shorter chassis plate so the overall wheelbase stays the same.
#287
Hey Jaybee,
I'll Try to answer these as best as i can
Part# DB1030R The difference between this part and the original is that it sets the shock back on the top pod it changes the leverage of the shock. I helps make the car rotate better.
Whats a nice feature on the DB12RR and the new Copper Head12 car is you can position the shock mount forward or back. It changes leverage on the pod and how much traction or less traction you want. So if you want more traction move the mount forward and if you want less traction move it to the rear.
Part# DB1020R This is different than the original this lengthens the car some it basically keeps the car more stable and I think a longer wheel base helps the car carry more corner speed I have to ask Jason on this.
Part# DB1041R this part is for the DB12RR car its pretty much like the original but its made for the DB12RR
Part#DB1053R Is the pod brace for the DB12RR car on this car the pod is a little wider to allow more room for brushless motors.
As for 1c lipo's there's many alot of people are using Thunder Power, Trinity just to name a few.
Hope this helps
Mike
Hope this helps
Mike
#288
Yes
#289
So, there will be an option to buy the Copperhead with the new suspension, but the cost will be higher than the Copperhead with the old Associated style front end, correct?
I do not mind paying more for the car . But I have a problem with having to buy two front ends with my kit, when I know I'm not going to use the Associated style front end. I'm confident many others agree with me .
#294
#295
Jason do you have an idea when the kits will be offered with the new front end, My son and I will be running this car for the carpet season. I think we will be starting next month sometime at the gate cant wait
#298
