Soldering Brushes? >
Soldering Brushes?
Soldering Brushes?
Old 04-10-2004, 07:39 AM
Default Soldering Brushes?
Hi, I was wondering were the best place to solder brushes onto a Monster Stock Motor is if I want the most power, thanks.
TC3er is offline
Old 04-10-2004, 07:43 AM
fatdoggy's Avatar
Some people say straight to the tabs so there is a more direct connection. I just solder to the hood and it seems to work fine.
fatdoggy is offline
Old 04-10-2004, 08:03 AM
The tabs that the wires from the speed controller goto.
A-Ko is offline
Old 04-10-2004, 08:58 AM
I solder to the hoods on the opposite side of the spring. this leaves a little more lead for the brush to move freely. I also hold the brush about 1/8 to 1/4 inch from the end you are soldering so it doesn't fill up with solder. The needle nose pliers act as a heat sink.
David Root
David Root is offline
Old 04-12-2004, 01:58 PM
Claydoh's Avatar
I quit soldering them and just trap the shunt under the spring above the hoods.
Claydoh is offline
